dmx examples
hy arduino friends!
i have a question while using the example
Build your own DMX Master device, dmxLab_01_clean_code
if i do compile there is an error;
In function ‘void shiftDmxOut(int, int)’:
error: ‘port_to_output’ was not declared in this scop
the code is;
/* DMX Shift Out for arduino - 004 and 005
 * Shifts data in DMX format out to DMX enabled devices
 * it is extremely restrictive in terms of timing. Therefore
 * the program will stop the interrupts when sending data
 * The elektronic foundation for DMX is RS 485, so you have to use
 * a MAX-485 or a 75176.
 * wirring for sending dmx with a MAX-485
    1 - RO  - Receiver Output --- set to ground with a 100 ohm resistor
    2 - RE  - Receiver Output Enable -- set to ground
    3 - DE  - Driver Output Enable -- set to 5v
    4 - DI  - Driver Input -- Input from Arduino
    5 - GnD - Ground Connection -- set to ground -- refence for the DMX singal --- (DMX pin 1)
    6 - A   - Driver Output / Receiver Input -- DMX Signal (hot)------------------ (DMX pin 3)
    7 - B   - Driver Output / Receiver Input -- DMX Signal inversion ( cold)------ (DMX pin 2)
    8 - Vcc - Positive Supply -- 4,75V < Vcc < 5,25V
 * Every dmx packet contains 512 bytes of information (for 512 channels).
 * The start of each packet is market by a start byte (shiftDmxOut(sig,0);),
 * you should always send all 512 bytes even if you don*t use all 512 channels.
 * The time between every dmx packet is market by a break
 * between 88us and 1s ( digitalWrite(sig, LOW); delay(10);)
int sig = 11;           //dmx pin 3
int count = 0;
int swing = 0;
int updown = 0;
/* Sends a DMX byte out on a pin.  Assumes a 16 MHz clock.
 * Disables interrupts, which will disrupt the millis() function if used
 * too frequently. */
void shiftDmxOut(int pin, int theByte)
    int wasteTime = 0;
    int theDelay = 1;
    int count = 0;
    int portNumber = port_to_output[digital_pin_to_port[pin].port];  //???????????????
    int pinNumber = digital_pin_to_port[pin].bit;                    //???????????????
    // the first thing we do is to write te pin to high
    // it will be the mark between bytes. It may be also
    // high from before
        _SFR_BYTE(_SFR_IO8(portNumber)) |= _BV(pinNumber);
    delayMicroseconds(10);
    // disable interrupts, otherwise the timer 0 overflow interrupt that
    // tracks milliseconds will make us delay longer than we want.
    cli();
        // DMX starts with a start-bit that must always be zero
        _SFR_BYTE(_SFR_IO8(portNumber)) &= ~_BV(pinNumber);
        //we need a delay of 4us (then one bit is transfert)
        // at the arduino just the delay for 1us is precise every thing between 2 and 12 is jsut luke
        // to get excatly 4us we have do delay 1us 4 times
        delayMicroseconds(theDelay);
         for (count = 0; count < 8; count++) {
                if (theByte & 01) {
            else {
              // to write every bit exactly 4 microseconds, we have to waste some time here.
              //thats why we are doing a for loop with nothing to do, a delayMicroseonds is not smal enough
              for (wasteTime =0; wasteTime <2; wasteTime++) {}
                theByte>>=1;
    // the last thing we do is to write the pin to high
    // it will be the mark between bytes. (this break is have to be between 8 us and 1 sec)
    // reenable interrupts.
    sei();
  pinMode(sig, OUTPUT);
  digitalWrite(13, HIGH);
void loop()  {
   // sending the break (the break can be between 88us and 1sec)
   delay(10);
   //sending the start byte
   shiftDmxOut(sig,0);
   shiftDmxOut(sig, 255); //1
   shiftDmxOut(sig, 0); //2
   shiftDmxOut(sig, 255); //3
   shiftDmxOut(sig, 0); //4
   shiftDmxOut(sig, 0); //5
   shiftDmxOut(sig, 0); //6
   shiftDmxOut(sig, 0); //7
   shiftDmxOut(sig, 255); //8
   for (count = 1; count<=504; count++){  //the rest
has anyone an idea how to do this?
thank you!!!
Check this thread:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1205193597/1
i read it and a did :
include "pins_arduino.h"
and define
int port_to_output[] = { NOT_A_PORT, NOT_A_PORT, _SFR_IO_ADDR(PORTB), _SFR_IO_ADDR(PORTC), _SFR_IO_ADDR(PORTD) };
and
rename
to
digitalPinToBitMask(pin)
so i have now;
int pinNumber = digitalPinToBitMask(pin); //int pinNumber = digital_pin_to_port[pin].bit;
but i still have a problem with;
with the same error.
i´m using arduino ng with 0010 alpha
any suggestion?
Not really--just thought it sounded like the problem you were having. As the second message in that thread says, maybe:
"Try replacing all instances of port_to_output with port_to_output_PGM in the sample code."
