Hi there.
I’m working on a home domotics system using an Arduino Mega. I’d like to use the following library: http://www.deskontrol.net/blog/arduino-four-universes-dmx-512-library/. Since the Mega has 4 UART hardwares, I’d like to use the 2nd one to drive the DMX. In the header of the DMX library I set it to only use UART1.
Now, when compiling I get the error:
core.a(HardwareSerial.cpp.o): In function __vector_36':* *C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/HardwareSerial.cpp:147: multiple definition of
__vector_36’
Dmx\lib_dmx.cpp.o:C:\Program Files (x86)\Arduino\libraries\Dmx/lib_dmx.cpp:206: first defined here
These lines correspond to the following pieces of code:
lib_dmx.cpp
#if defined(USE_UART1)
ISR (SIG_USART1_RECV)
ArduinoDmx1.Process_ISR_RX(1);
#endif
HardwareSerial.cpp (line with ISR in it)
#if defined(USART1_RX_vect)
void serialEvent1() __attribute__((weak));
void serialEvent1() {}
#define serialEvent1_implemented
ISR(USART1_RX_vect)
if (bit_is_clear(UCSR1A, UPE1)) {
unsigned char c = UDR1;
store_char(c, &rx_buffer1);
#endif
My full program code is:
include files
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <lib_dmx.h>
#define DMX512 (0)
byte mac[] = { 0xDD, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(10,0,0,2); // TODO: assign ip address from DHCP
unsigned int multicastPort = 8888;
IPAddress multicastIp(239,0,0,57);
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
EthernetUDP Udp;
int sensorValue = 0;
int ledState = 0;
int DMXPin = 0;
// DMX
ArduinoDmx1.set_control_pin(DMXPin);
ArduinoDmx1.set_rx_channels(1);
ArduinoDmx1.set_tx_channels(5);
ArduinoDmx1.init_tx(DMX512);
Ethernet.begin(mac,ip);
Udp.beginMulti( multicastIp, multicastPort );
int packetSize = Udp.parsePacket();
if(packetSize){
Serial.print("Received packet of size ");
Serial.println(packetSize);
Serial.print("From ");
IPAddress remote = Udp.remoteIP();
for (int i =0; i < 4; i++){
Serial.print(remote[i], DEC);
if (i < 3){
Serial.print(".");
Serial.print(", port ");
Serial.println(Udp.remotePort());
Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);
Serial.println("Contents:");
Serial.println(packetBuffer[0]);
ArduinoDmx1.TxBuffer[0] = (int)packetBuffer;
I’m also using an adjusted Ethernet Library that supports UDP multicast (found here: GitHub - aallan/Arduino: open-source electronics prototyping platform ).
I’m not that familiar with the interrupts on Arduino, but I really have no idea how to fix this. I want to use the first UART for debugging, the second for DMX, and the other ones should be for communication with other Arduino’s.
