Hi, i have a problem.
A have pro mini and it´s connect via max 485 to DMX device. It connected for one second and then disconect. When i reset (unplug and plug to usb) it ´s repeat (connect for one second und disconect) Why? please help me
Peter
Pins 2 and 3 should both be either pulled high, or pulled low, depending on whether you want to transmit or receive. right now you have told the chip to enable both, which is probably causing logic problems. In your case it looks like you are trying to transmit, so both pins should be pulled high. I have also had problems with 485 chips that didn't have a .1uf decoupling cap near them.
The data sheet looks like 2, 3, and 4 need to vary between HIGH and LOW depending on whether you receiving or transmitting and depending on what you are transmitting.
It looks like in your schematic that 2 is always LOW (connected to GND) and 3 is always HIGH (connected to VCC). If 3 is always HIGH, it looks like varying 4 will vary the outputs on 6 and 7.
Maybe you could show how the MAX485 is connected?
I am entirely unfamiliar with how the DMX protocol is handled. Maybe if you talked through it (and gave us a lesson at the same time- hint, hint) it would help you solve the problem?
The 100 ohm termination resistor goes between pins 6 and 7 (but can be
omitted if only ever transmitting and not receiving, as for simple DMX). It
doesn't belong on pin 1.
DMX has no notion of connected or disconnected, you just blast packets out
all the time.
