I'm using the DMX simple library to control RGB LEDs. The LEDs dont like the DMX from the Arduino.
The manufacturer stated the following:
The problem is the "SPACE" for BREAK of the TRISTAR-RGB-DMX, which is 500. The standard DMX "SPACE" for BREAK is 88~144, but some DMX controllers handle a wide range of from 88~1,000.
So at this point, unless we can get our engineers to change the "SPACE" for BREAK, you need a DMX controller than can handle 500.
I've had a look at the DMX simple code, but I'm out of my depth, looks to me that this is the important section:
/** Transmit a complete DMX byte
* We have no serial port for DMX, so everything is timed using an exact
* number of instruction cycles.
* Really suggest you don't touch this function.
void dmxSendByte(volatile uint8_t value)
uint8_t bitCount, delCount;
asm volatile (
"cli\n"
"ld tmp_reg,%a[dmxPort]\n"
"and tmp_reg,%[outMask]\n"
"st %a[dmxPort],tmp_reg\n"
"ldi %[bitCount],11\n" // 11 bit intervals per transmitted byte
"rjmp bitLoop%=\n" // Delay 2 clock cycles.
"bitLoop%=:\n"\
"ldi %[delCount],%[delCountVal]\n"
"delLoop%=:\n"
"nop\n"
"dec %[delCount]\n"
"brne delLoop%=\n"
"sec\n"
"ror %[value]\n"
"brcc sendzero%=\n"
"or tmp_reg,%[outBit]\n"
"sendzero%=:\n"
"dec %[bitCount]\n"
"brne bitLoop%=\n"
"sei\n"
[bitCount] "=&d" (bitCount),
[delCount] "=&d" (delCount)
[dmxPort] "e" (dmxPort),
[outMask] "r" (~dmxBit),
[outBit] "r" (dmxBit),
[delCountVal] "M" (F_CPU/1000000-3),
[value] "r" (value)
The section you quoted transmits a single byte - it does not transmit the break part. You're looking in the wrong place.
The break is sent in the dmxState==0 state of the TIMER2_OVF_vect interrupt routine. The code there isn't exactly the most hackable - its pretty bodgy there. I'll see what I can do to give you an adjustable break length.
By the way, excellent work discovering the break length problem. Makes fixing it a whole lot easier.
I believe this is the code in question. Basically increasing the number 35 to something longer in both places should increase the start break time. If 35 bits = 88us, and you need 500us, then roughly x8, i.e. (35*6=210).
if (dmxState == 0) {
// Next thing to send is reset pulse and start code
// which takes 35 bit periods
uint8_t i;
if (bitsLeft < 35) break;
bitsLeft-=35;
*dmxPort &= ~dmxBit;
for (i=0; i<11; i++) _delay_us(8);
*dmxPort |= dmxBit;
_delay_us(8);
dmxSendByte(0);
