I'm working on a DMX lighting project and have it working for the most part. This uses the DMXSerial and FastLED libraries. I'm feeding the DMX signal in to a MAX485 chip to convert it into serial data that's picked up using DMXSerial on the RX pin. It reads the three channels (RGB - 1,2,&3 respectively) just fine. This data is a value between 0-255 based upon the fader.
The issue is that the stream of data seems drop to 0 about once every second on all channels. It's not the input to the RX pin, just the output pin 6. This can been seen in the serial monitor also.
For example:
128
128
128
128
128
0
128
128
Is this a limitation of using the serial interface?
#include <DMXSerial.h>
#include <FastLED.h>
const int OutPin = 6; // Output pin for RGB data.
// This Example receives the 3 values starting with this channel:
const int startChannel = 0 * 3 + 1;
#define LED_QTY 23 // Number of LEDs in strip
#define BRIGHTNESS 255 // brightness range [0..255]
#define CHIP_SET WS2812B // types of RGB LEDs
#define COLOR_CODE GRB //sequence of colors in data stream
// Define the array of LEDs
CRGB LEDs[LED_QTY];
DMXSerial.init(DMXReceiver);
FastLED.addLeds<CHIP_SET, OutPin, COLOR_CODE>(LEDs, LED_QTY);
FastLED.setBrightness(BRIGHTNESS);
FastLED.setMaxPowerInVoltsAndMilliamps(5, 500);
FastLED.clear();
//FastLED.show();
// enable outputs
pinMode(OutPin, OUTPUT); // sets the digital pin as output
// Calculate how long no data bucket was received
//unsigned long lastPacket = DMXSerial.noDataSince();
//if (lastPacket < 5000) {
// read recent DMX values and set levels
//Serial.print(" Start Channel = ") + Serial.println(startChannel);
Serial.println(DMXSerial.read(startChannel));
for (int i = 0; i < LED_QTY; i++)
LEDs[i] = CRGB(DMXSerial.read(startChannel), DMXSerial.read(startChannel + 1), DMXSerial.read(startChannel + 2));
FastLED.show();
//} else {
//} // if
// End.
