Dns.h 'dnClient' does not name a type
I will appreciate every help. I found simple example of code with dns library. But for some reason I don’t understand why it dont work. I tryied to find solution on web. I tryied on another laptop with clear arduino IDE instalation without luck. What is the problem?
Code:
#include <Dns.h>
DNSClient dnClient;
dnClient.begin(Ethernet.dnsServerIP());
Error message:
dns_test:5:1: error: ‘dnClient’ does not name a type
It uses Ethernet library: Arduino\libraries\Ethernet
With regards Daniel J.
Put the offending line inside the setup function.
With few exceptions, all C/C++ code must be inside a function.
Yes, thank you. This is when you use arduino once a time not frequently.
