DNS Lookup on MKRNB
Hello everyone.
Is there any functionality within the MKRNB library or related to narrowband connectivity that supports DNS lookup to obtain an IP address from a hostname?
I am hosting a CoAP server at home and I do not want to go through the trouble of converting my public IP to static. This is why I am opting to go for a Dynamic DNS service instead.
I was hoping to find some functionality similar to getHostByName() from the Ethernet library but to no avail.
Thanks in advance
Hello
The MKR1500 is in the mobile network therefore gets it's IP / DNS configuration from the network carrier and you can't get out of this mobile net. DynDNS won't work.
Just to clarify, I am looking to send packets from the MKRNB1500 to a CoAP server of which its IP is dynamic. Unfortunately, the CoAP library only supports entering an IPAddress object rather than a hostname which I can get easily from a Dynamic DNS service such as NoIP.
AT+UDNSRN=0,"ftp.u-blox.com"
Sorry for taking longer than usual to respond. But I have tried it multiple times with multiple hostnames and it kept returning ERROR on the serial output.
It just turns out that the AT+UDNSRN AT Command is not supported by the SARA-R410M-02B-00, per https://portal.u-blox.com/s/question/0D52p00008HKCscCAH/sarau201-cme-error-after-atudnsrn which just happens to be the chipset on the MKRNB1500.
sigh
