do an action between two hours
Dear Friends,
In this opportunity I writing to you asking help in order to find a solution to this short sketch. The main purpose is to powering a sensor through the enabling of a pin according to the hour (starting and finish hour) given by a RTC.
Although the IDE can compile the sketch and the serial print can work, the snippet "if" statement does not work.
I appreciate so much your help.
Kind Regards,
#include <Sodaq_DS3231.h>
#include <Wire.h>
// set pin numbers:
const int ledPin = 13;
const int powerPin =  8;      // the number of the power pin
const uint8_t horaInicio = 17; // set thestating hour
const uint8_t horaFin = 19;  // set the finish hour
  pinMode(powerPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  Wire.begin();
  rtc.begin();
  DateTime now = rtc.now(); //get the current date-time
  Serial.print(now.hour(), DEC);
  delay (2000);
  if ( horaInicio <= now.hour() >= horaFin )
    //power on
    digitalWrite (powerPin, HIGH);
    // turn LED on:
    digitalWrite(ledPin, HIGH);
  else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
  delay (1000);
powerPin_8.ino (771 Bytes)
That will not work.
I think maybe what you meant is this:
 if ((horaInicio <= now.hour()) && (now.hour() <= horaFin))
but I still think maybe that is not what you wanted.
Look again at this:
Do you want the light to be on from 17:00 to 19:00?
Or do you want it to be on from 17:00 through 19:59 (and turn off at 20:00)?
Think about it: if the time is 19:59, then now.hour() will still be 19.
Maybe what you want is this:
 if ((horaInicio <= now.hour()) && (now.hour() < horaFin))
Thank you! now it is working, i want that the sensor works from 17:00 to 19:59 (sensor turns off at 20)
