Do functions leak memory if the return is in a middle of something?
I just put a return instruction in a middle of an while/if test. Does it leak memory? By the way, sorry about Finnish names in the variables. I am reinventing the GSM wheel and I don't like at like at all.
int read_sms()
int varao, varak, varaln, varaf, loppu;
char merkki[2];
int laskuri;
strcpy(viesti,'\0');
strcpy(merkki,'\0');
Serial1.print("AT+CMGRD=0");
Serial1.print('\r');
Serial1.print('\n');
loppu=0;
varao=0;
varak=0;
varaln=0;
laskuri=0;
while (loppu!=1)
while(Serial1.available() > 0 )
varaf = Serial1.read();
laskuri++;
varao=varak;
varak=varaln;
varaln=varaf;
varaf=sprintf (merkki,"%c",varaf);
if (varaln=='\r' && varao=='O' && varak=='K')
loppu=1;
//error, no more messages
if (laskuri==22 && varao=='E' && varak=='R')
loppu=1;
 Serial.println("error no more msg");
 //is this bad
 return 0;
strcat(viesti, '\0');
return laskuri;
No.
Mark
If you have any evidence that it does, you should post it as a bug.
KenF:
I sure will. But it is better to find the bugs now than later.
LMI:
You can assume that this bug doesn't exist.
I can see bugs and design errors in you're code but they are yours and NOT C/C++ or IDE bugs. Try laying out your code (which is some thing you should do before posting in any case).
Mark
Hint: Here are the first two bugs
holmes4:
Mark
Memory leaks may or may not happen, no matter what I'll do elsewhere. There sure are bugs
LMI:
So, fix the bugs in the snippet you've posted. You've got the clues.
