Do have any idea about this ?
c:\Users\Admin\OneDrive\Documents\Arduino\libraries\CAN\src\ESP32SJA1000.cpp:6:10: fatal error: esp_intr.h: No such file or directory
6 | #include "esp_intr.h"
compilation terminated.
exit status 1
Compilation error: exit status 1
i have reinstall all things but still i got that error
Welcome to the forum
As your topic does not relate directly to the installation or operation of the IDE it has been moved to the Programming category of the forum
Which Arduino board are you using and which board have you got selected in the IDE ?
Are you sure you are compiling an Arduino code and not an ESP-IDF code?
Also which version of the core do you have?
Try replacing the include with
#include "esp_intr_alloc.h"
which CANbus library are you using?
for the ESP32 I would recommend using the onboard Two-Wire Automotive Interface (TWAI) which only requires an external CAN transceiver
I have deleted your other cross-post @tejasc457.
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
esp_intr.h is a header file that defines the interrupt types and macros for the ESP32 microcontroller. It includes the ETS_SYS and xtensa_api headers and provides functions to attach, enable and disable interrupt handlers.
Further...
The header file esp_intr.h has been deleted. Please include esp_intr_alloc.h to allocate and manipulate interrupts.
