Do I need a heatsink?
I touched the top of a 7833 regulator yesterday - this pic was taken 24hrs later - I think I might need a heatsink!! :slight_smile:
G.
Heatsink is for crybaby!
Use a supraconductor and you won't heat-up anything ;D
Everytime I touch something to see if it is overheating, I think "why did I just do that?!" I'm guessing you had the same thought when that happened....
Nah, just put some bondo on that finger dent and sand it down, will not even show. :wink:
Lefty
Did you expect sympathy?
The trick is not to press down when you make your initial contact.
I once dropped a soldering iron and then instinctively caught it, then dropped it again. But only once. ;D
Mike, It took me 2-3 drops before the instinct to let it fall kicked in. Now its about moving my shoeless foot out the way when soldering at home(who am I kidding, I take my shoes off at work).
I once dropped a soldering iron and then instinctively caught it, then dropped it again. But only once. Grin
I guess I am not as lucky as you Mike. After all these years, I still manage to grab right onto the soldering iron at least once a month! :-X
As lucky or as smart? ;D
Timeout! >:(
I had a similar mark to that thanks to a diode I was not paying attention to
it went away after a couple weeks, though the time I was pushing a 556 timer into some card stock and it seated in my finger hurt much worse
All I have to add to this thread is tell you:
Never, I mean NEVER, solder naked.
:wink:
Not at all! If I don't get it from my wife then I'll hardly get it from you lot!!
My 5yo daughter did show some concern, before skipping off into the distance! :slight_smile:
Ouch! Were you mono-stable or astable afterward!? :wink:
G.
defiantly astable
I would be fine and forget it, but then I would "go high" in pain by mashing it or something
