DO I NEED A PROGRAMMER for MEGA 2560 ?
Helo every one. I just get an arduino mega 2560 . Do I need a programmer for uploading the program ? Or not ? Please tell me. I am just a beginer with these all.
No, you don't have to employ a programmer, you can write the code yourself.
no if you have a arduino mega it should have the bootloader installed, just select it from the boards menu and off you go
AWOL the question was to upload not create, very paulS of you :0
Osgeld: no if you have a arduino mega it should have the bootloader installed, just select it from the boards menu and off you go
That's Mr PaulS to you good sir. He is very case sensitive about such things. ;)
Lefty
I conect the boad arduino mega 2560 only with usb. I open the program: ( Arduino erg 1.0.2) I open an example. I do compile. Is ok. I do upload.
And now its write: Done uploading. OK . (It can see the board in com 14. OK)
But : with red letters writes:avrdude. exe:cant find programmer id wiring valid programmers are: .......
On TOOLS: I chooce: Programmer: Arduino as isp . (is it ok?)
No. You should just choose Board, then "Arduino Mega 2560 or Mega ADK".
SERET: I conect the boad arduino mega 2560 only with usb. I open the program: ( Arduino erg 1.0.2) I open an example. I do compile. Is ok. I do upload.
No that's wrong. I use "AVRISP mkII" as programmer (which was the default when I installed). As I have understood "Arduino as ISP" is used when you want to use your connected arduino to upload onto anther arduino (one perhaps custom built without USB).
So select that, change to "Arduino MEGA 2560 or ADK" under Tools->Board. And if it doesn't work, verify that the COM port used under Tools->Serial Port is actually the one used by your arduino, which you can find in device manager if your using windows.
