Do i need a shield?
Hello Guys.
Do i need a shield to run a DC motor with my board?
  • Ka---ka
Well you don't have to use a shield to run just one DC motor.
You can use the L293 motor driver IC(http://akashxav.com/2009/04/18/arduino-l293d-dc-motor/)
But if you are planing to use more then one then it would be easier to use this shield : Motor Shield - Arduino motor/stepper/servo control
Depending on how much current the motor draws, you might be able to control it with just a transistor like the TIP120, and a diode and a couple of resistors.
There are basically four popular ways to go when wishing to build external components using an Arduino.
  1. Design and build your own custom made PCB.
  2. Buy a commercial shield that performs the function you want.
    Example: Breadboard - Classic - PRT-00112 - SparkFun Electronics
  3. Buy a protoshield and add your component design to it.
    Example: http://www.sparkfun.com/commerce/product_info.php?products_id=7914
  4. Use a commercial solderless breadboard and build your external components on it. Example: Breadboard - Classic - PRT-00112 - SparkFun Electronics
I tend to use 3 and 4. #4 to test out a circuit and then move it to #3 if I want a permanent module from the design.
Lefty
