Hi, I'm currently working on a project involving A4988 Stepper Drivers.
I'm using a knockoff PCB Board, like this one: botland.de
I am using 4 of these with modified 28bj-48 Stepper motors, but somehow they only work sporadically. I've connected them like this:
VDD -> 3.3V
VMOT -> 8V
Pins A1-B2 -> corresponding Motor pins
GND -> 0V
EN -> not connected, but seems to be pulled low using a 100k resistor
MS1, MS2 and MS3 are tied together, I only need full steps. They are left unconnected, but seem to be pulled low by a 90k resistor-
SLEEP and RST -> connected together
STEP and DIR -> connected to my microcontroller
When sending step signals, the motor sometimes works, but other times doesn't. When I connect EN to GND using a Wire, it works. But shouldn't it work without this wire? It is pulled low using a 100k ohms resistor on the board.
I'm wondering if it's safe to just connected it straight to GND without a resistor?
I appreciate every answer
Okay, I will add some info. I bought the drivers from a eBay Vendor, so no Datatsheets or Schematics., they are at least visually the same as the ones in the link, same pinout and component placement. I modified the 28bj-48 Stepper to be bipolar, by cutting the common +5V PCB trace, according to this tutorial: https://www.youtube.com/watch?v=lLF9_rc9G3I
I am using a ESP32 Dev board. I hope this info helps
That's not at all good enough. This is not about make up, it's about electronics and precision is a must.
That's a mistake buying such things.
Sorry but I don't spend time watching tutorials, often made by ignorant people.
The 28bj-48 stepper is a 50 Ohm stepper and it's not compatible with the A4988 driver. That driver works with low Ohm steppers that need current controlled. The 28bj-48 is not that type.
"That's a mistake buying such things." I'm a student and this is for a hobby project, I didn't want to spend too much money, so I ordered from eBay. I guess I will have to order them from a different seller. But the Drivers seem to be working well some times, so I don't think that the driver is broken.
I don't understand this. Sure, the normal, unmodified (unipolar) version isn't compatible, but when removing the common 5V, it's just a normal bipolar stepper. And the current is controlled by the current limiting driver. (The current is set by the potentiometer). So the coil resistance shouldn't matter, right?
Small Update, all 4 Motors and drivers work now. There was a short between EN and 3.3V. I fixed it, and it seems to work flawlessly. Of course I will do some further testing, but not today anymore. Thanks for your help
VMot is 8v, because I drive the motors with a 2S Lipo battery(8.4V when full and ~7V when empty). I'm using a boost-buck converter to keep the voltage at 8V. I mainly modified the steppers because I didn't think it would work without the modification, right? The A4988 driver can't drive unipolar steppers. That's why I modified the 28bj-48. My application requires very little torque and speed, so not that important. But I might try out 12V or 24V at some point.
I didn't use the ULN2003 boards, because they are way to big and require to many pins for my application. In my tests, the A4988 worked well until ~7.4V. I'm planning to use a 3S lipo(11.1V nominal voltage) in the future, that will ensure reliability
