Do I need resistors?
Hi everyone
I'm building a temp sensor and thermostat for 4 reptile cages It's pretty simple
I'll connect 4 lm35 temp sensors (0-100ºc) to the analog pins, each monitoring different reptiles terrariums. At the same time, i'll connect a 4 relay module (octocoupler) that will turn on/off 4 different 110v heat tapes in each terrarium.
Do I need resistors somewhere in this circuit? Where? And how many ohms?
Thank you a lot
No resistors needed.
just be sure to wire those relay's correctly
|500x164
I've noticed that a 1k resistor between LM35 output and analog input pin helps with "jitters", also a 100nF ceramic capacitor from analog in pin to GND doesn't hurt. You would get better resolution using the internal 1.1V analog reference than the default VCC. @Hutkikz: Good point on the relays.
Hutkikz: No resistors needed.
|500x164
Thank you all for the answers
I can't understand this diagram. Do I need to connect the separate DC supply AND the VCC connection to the Arduino?? Not only one?
Since you are dealing with 'life' make sure you have a fallback circuit.
Internal connections are probably similar to this:
No, VCC goes to the Arduino 5volt.
JD-VCC goes to the separate 5 volt power supply.
Do not connect the ground from the relay board to the Arduino.
As CrossRoads picture shows This keeps the load power isolated from the Arduino.
CrossRoads: Internal connections are probably similar to this:
Or a trifle neater, |500x205
