Hi, may I have an opinion on this please?
Everything is working so far but Cue #3 is not. What I want that cue to do is : While the pushbutton is depressed rotate the stepper at a certain speed while triggering the "travel" sound and looking for both the "danger" sensor and the "fall" sensor which will then trigger their respective sounds, and as soon as the button is released stop the stepper and play the "ding" sound. From what I've read here I should really be using a State Machine and individual functions to do this instead of the structure that I have? The demo code for "Several Things at the Same Time" uses the servo library so should I use the stepper library since I'm just counting steps for the set distance moves?
Also I'm not sure I formatted the code correctly. Saved it as html from VScode, reopened it and copy pasted with preformatted text tool but I keep getting the warning?
Thanks!
#include <Arduino.h>
// Control for Cliffhanger game. Made by David Parker nlightn0@gmail.com 04/01/2022
*******************************Overview of button behaviors*************************************
1)Start button: Random goat move 1-12 spaces along the track. Each move different.
Beginning yodel to start, then Traveling music track plays during movement. When the figure stops, a
bell “DING”
2)Go directly to space #24. Beginning yodel to start, then plays music while it travels and
when the figure stops a bell “Ding”
3)Manual run. Beginning yodel to start, character moves until host takes finger off button then the stop DING
4)Sound track win..play sound ding ding ding ding and winning music
5)Sound track lose…loosing sound, and music
6)Idle music.
7)Resets game to start position moves goat to starting position. No sound.
********************************Electromagnetic triggers***************************************
An electromagnet creates a “start of game” sound when he crosses position one.
An electromagnet at the top of the mountain would trigger a sound effect - falling yodel sound
Perhaps another electromagnet could trigger red flashing lighting
and a sound effect that warns that the goat is going to fall off when it passes.
*********************************Pinouts for Sound Board***************************************
T01HOLDL.ogg Travel Music
T02.ogg Losing (Falling Yodel) Sound
T03.ogg Winning Sound
T04.ogg 1 Ding
T05.ogg Danger Sound
T06LATCH.ogg Idle Music
T07.ogg Buzz
T08.ogg Reset Game Music
const int speed1 = 1000;
const int speed2 = 250;
//********************************LECTERN BUTTONS*********************************************
const int reset = 4; //Cue 7 : Moves goat to Start of game location : resetPin
const int randomMove = 5; //Cue 1 : Moves goat random distance between resetPin and dangerPin
const int space24 = 6; //Cue 2 : Moves goat to just before dangerPin (space 24)
const int manual = 7; //Cue 3 : Moves goat until button is released
const int win = 8; //Cue 4 : plays win sound
const int lose = 9; //Cue 5 : plays lose sound
const int idle = 10; //Cue 6 : plays win sound
//********************************SOUND TRIGGERS**********************************************
const int travelSoundPin = 30; //pin 1 on sound board : Hold Looping Trigger
const int fallSoundPin = 31; //pin 2 on sound board : Basic Trigger
const int winSoundPin = 32; //pin 3 on sound board : Basic Trigger
const int dingSoundPin = 33; //pin 4 on sound board : Basic Trigger
const int loseSoundPin = 34; //pin 5 on sound board : Basic Trigger
const int idleSoundPin = 35; //pin 6 on sound board : Latching Loop Trigger
const int dangerSoundPin = 36; //pin 7 on sound board : Basic Trigger
//********************************SENSORS AND MOTOR CONTROL***********************************
const int resetPin = 24; //Start of game location
const int dangerLocationPin = 25; //Play Danger Sound
const int fallPin = 26; //Play Lose Sound
const int stepPin = 22; //Stepper Motor Control
const int dirPin = 23;
//********************************Button 3 Variables******************************************
int buttonState = 1;
int lastButtonState = 1;
pinMode(4, INPUT_PULLUP); //Cue 7 return to home position
pinMode(5, INPUT_PULLUP); //Cue 1 random move space 1 - 12
pinMode(6, INPUT_PULLUP); //Cue 2 go to space 24
pinMode(7, INPUT_PULLUP); //Cue 3 manual move
pinMode(8, INPUT_PULLUP); //Cue 4 winning sound 1x
pinMode(9, INPUT_PULLUP); //Cue 5 losing sound 1x
pinMode(10, INPUT_PULLUP); //Cue 6 idle music loop
pinMode(24, INPUT_PULLUP); //optical sensor - home position
pinMode(25, INPUT_PULLUP); //optical sensor - triggers DANGER sound
pinMode(26, INPUT_PULLUP); //optical sensor - triggers LOSE sound
pinMode(travelSoundPin, OUTPUT);
pinMode(fallSoundPin, OUTPUT);
pinMode(winSoundPin, OUTPUT);
pinMode(dingSoundPin, OUTPUT);
pinMode(loseSoundPin, OUTPUT);
pinMode(idleSoundPin, OUTPUT);
pinMode(dangerSoundPin, OUTPUT);
pinMode(stepPin, OUTPUT);
pinMode(dirPin, OUTPUT);
digitalWrite(travelSoundPin,HIGH);
digitalWrite(fallSoundPin,HIGH);
digitalWrite(winSoundPin,HIGH);
digitalWrite(dingSoundPin,HIGH);
digitalWrite(loseSoundPin,HIGH);
digitalWrite(idleSoundPin,HIGH);
digitalWrite(dangerSoundPin,HIGH);
//read the buttons into variables
//Cue #7, Reset to Home Position, Button 7 > Pin 4 INPUT > STEP/DIR, No Music
int sensor7Val = digitalRead(4);
int sensor8Val = digitalRead(24);
if (sensor7Val == LOW && sensor8Val == HIGH) {
digitalWrite(dirPin,HIGH); // Enables the belt to move forward
digitalWrite(stepPin,HIGH);
delayMicroseconds(speed2);
digitalWrite(stepPin,LOW);
//Cue #1, Random Move, Button 1 > Pin 5 INPUT > STEP/DIR, Travel music then Ding sound
int sensor1Val = digitalRead(5);
int randMove = random(3000);
if (sensor1Val == LOW) {
digitalWrite(travelSoundPin,LOW);
// Makes random number of pulses to go to space 12 at the furthest
for(int x = 0; x < randMove; x++) {
delayMicroseconds(speed1);
int dangerVal = digitalRead(dangerLocationPin);
if (dangerVal == LOW) {
digitalWrite(dangerSoundPin,LOW);
digitalWrite(dingSoundPin,LOW);
delay(25);
//Cue #2, Space 24 Move, Button 2 > Pin 6 INPUT > STEP/DIR, Travel music then Ding sound
int sensor2Val = digitalRead(6);
int sensor9Val = digitalRead(24);
if (sensor2Val == LOW && sensor9Val == LOW) {
// Makes 6000 pulses to go to space 24
for(int x = 0; x < 6000; x++) {
delay(25);
//Cue #3, Manual Move, Button 3 > Pin 7 INPUT > STEP/DIR, Travel music then Ding sound
buttonState = digitalRead(7);
if (buttonState != lastButtonState) {
if (buttonState == LOW){
//int dangerVal = digitalRead(dangerPin);
//if (dangerVal == LOW) {
//digitalWrite(dangerSoundPin,LOW);
delay(15);
lastButtonState = buttonState;
//Cue #4, Sound Track WIN, Button 4 > Pin 8 INPUT > Pin 33 OUTPUT > Pin 3 on sound board
int sensor4Val = digitalRead(8);
if (sensor4Val == HIGH) {
digitalWrite(winSoundPin, HIGH);
else {
digitalWrite(winSoundPin, LOW);
//Cue #5, Sound Track LOSE, Button 5 > Pin 9 INPUT > Pin 34 OUTPUT > Pin 2 on sound board
int sensor5Val = digitalRead(9);
if (sensor5Val == HIGH) {
digitalWrite(loseSoundPin, HIGH);
else {
digitalWrite(loseSoundPin, LOW);
//Cue #6, Sound Track IDLE MUSIC, Button 6 > Pin 10 INPUT > Pin 35 OUTPUT > Pin 6 on sound board
int sensor6Val = digitalRead(10);
if (sensor6Val == HIGH) {
digitalWrite(idleSoundPin, HIGH);
else {
digitalWrite(idleSoundPin, LOW);
