I wrote a string split function witch splits a string which contain integers separated by semicolons into separate integers. The string contains 24 integers so I need to make it 24 times. Here is an example of the 2 first integers split :
My question is : Do I need to reset semicolunPosition to 0 after each integer and reset the trimIncomingString to "" at the end of the function for a new loop or will they reset by semselves after new assignment ?
We can’t see where trimIncomingString is populated, so it might if it is populated using ‘+=’ and you do not want the old data. If there is only a simple assignment, then it is replaced.
My trimIncomingString is obtained by assignement. So, if I well understand, only variables obtained by += have to be cleared for new usage ? Variables obtained by assignement are automatically reset when a new assignement is done ? Can you confirm ?
I need to simplify my sketch because I have to care about the size of it because it is a very big sketch and the Uno memory is limited.
JP744:
Variables obtained by assignement are automatically reset when a new assignement is done ? Can you confirm?
loose the notion of reset, a String can be assigned an empty string, and an int can be assigned zero, if this is what you need. If you need it to have real data, then just assign that to it.
JP744:
The += operator is one example. I used it as the String library overloads it. If you have control of the code, just change the ‘+=’ to ‘=’. Do you understand the differences between the two?
Then you should probably stick to character arrays instead of the String library. To a novice C++ programmer the memory usage can seem quite unpredictable when using Strings.
