Hi
Im planning to use 5x7 VFD Matixes, there are bi-color, so its basically a 5x14 Matrix, and just like a LED-Matrix
These are controlled by special VFD IC's which contains a 32bit Shift register.
If i want to use 6 Displays, i have to shift out 192 bits.
A Arduino running on 16MhZ, so one cycle is about 63ns!
Lets say i just want to multiplex 2 Lines, on all displays, would result in 384bits x 63ns = 0.025ms ! And thats only when the code has to do nothing else....
I fear that in the real projects this combination will result in "heavy flickering of the displays, because if i want to multiplex 2 lines individually per display, this would result in 0.15ms.
Is my theory right?
Would it be a better option, to use a single arduino per display (just the Atmega) and connect them per I2C?
