I have a home control project that monitors switches and runs a ventilation system. I want it to exit the loop and blink the LED on pin13 every few seconds as a system “OK” indication. It performs as expected for about 30-40 (I didn’t count them) cycles, with the LED blinking every 2 seconds, then the LED starts blinking as if the Do Loop is no longer being executed, eg, the blinker flashes as quickly as possible.
Is there something about millis() that I don’t understand? (loop_start is an unsigned long) I suspected something in the called functions was causing the problem but I commented them out so that there is nothing inside the Do Loop and the behavior is the same.
// ------------Main Program Loop------------
loop_start = millis() ;
do {
// check_clocks() ;
// if(switch_query()) { // is any switch line at logic 0?
// if(valid_switch()) { // a valid switch activation waits here for release
// switch_action() ; } } // yes, it's valid; change the light control words
} while(millis() - loop_start < 2000 ) ; // 2 seconds between blinker
blinker(50) ;
} // blink every 2 seconds; end of LOOP
// -----------End Main Program Loop---------------
void blinker(int a) { // blink for "2a" msec
delay(a / 2) ; // ensure there is a blink
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(a); // wait for "a" msec
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
delay(a / 2) ; } // ensure there is a blink, end of blinker
Arctic_Eddie:
It probably lasted 32.77 seconds because loop_start is likely a 16 bit unsigned integer. Change it to 32 bits.
No he said - loop_start is an unsigned long (but is it really we don’t know because we can’t see…)
so I tried this code and I don’t see the behavior you describe.
unsigned long loop_start;
const int led = 13;
pinMode(led, OUTPUT);
do {
} while (millis() - loop_start < 2000 ) ; // 2 seconds between blinker
blinker(50) ;
delay(a / 2) ;
can you try again with that exact code? we don’t know what your setup() looks like and if you trigger any timer or interrupt or anything… so a lot can happen in the code we don’t see.
char ver[] = "Fan_ver_A 10/11/16" ;
char chan1[] = "Fans w/o lights" ;
char chan2[] = "Fans off in 7 mins" ;
int led = 13 ;
int loop_count ;
byte bad_switch = 0 ; // stores continuously pressed (bad) switch
byte sw_pressed = 0 ; // stores which switch was pressed
byte pressed_mask = 0 ; // ensures that only one switch is tested
// The fan automatically will switch off 7 minutes after it is turned on.
// Fans can be manually turned off with the fan switch.
unsigned long mbath_clock ; // timers for auto fan shutoff
boolean mbath_flag ;
unsigned long powder_clock ;
boolean powder_flag ;
unsigned long bsmt_clock ;
boolean bsmt_flag ;
unsigned int off_time = 420000 ; // 420,000 is 7 minutes in msecs
// When the fan is switched by the light timers, it is generally switched
// on 2 minutes after the light is turned on and is switched off 5 minutes
// after the light is turned off. The fans can be manually turned off with
// the fan switch. The light algorithm uses the same countdown timers and
// timers are running flags as are used in the switch algorithm.
int prev_mbath_lt = B00001000 ; // previous state of the shower lights,
int prev_bsmt_lt = B00100000 ; // which are assumed to be off.
unsigned int mbath_time_on ; // time when the shower light switched on
unsigned int bsmt_time_on ;
boolean mbath_lt_flag = false ; // master shower lights timer is running
boolean bsmt_lt_flag = false ;
unsigned int lt_off_time = 300000 ; // 300,000 is 5 minutes in msecs
unsigned int lt_delay = 120000 ; // delay for fan to turn on
unsigned int loop_start ; // timer for the "I'm OK" blinker
// ---------------SETUP---------------------
pinMode(led, OUTPUT) ; // for test only
// include IcC library and set up ports 8 & 9 for temperature measaurement
DDRD = DDRD & B00000011; // sets Port D bits 2-7 to input
Bits 0 & 1 are reserved for serial comm
Bit 2 = Masteer Bath Fan Switch
Bit 3 = Master Bath Shower Light
Bit 4 = Basesment Shower Fan Switch
Bit 5 = Basement Shower Light
Bit 6 = Powder Room Fan Switch
Bit 7 = Isolation Door
digitalWrite(2, HIGH) ; // turn on the input pullup resistors
digitalWrite(3, HIGH) ;
digitalWrite(4, HIGH) ;
digitalWrite(5, HIGH) ;
digitalWrite(6, HIGH) ;
DDRB = DDRB | B00011100; // sets Port B bits 2-4 to output
PORTB = PORTB | B00010000 ; // Turn HRV off
Bits 0 & 1 are I2C for temperature measurement
Bit 2 = Main Fan
Bit 3 = Main Damper
Bit 4 = HRV on
DDRC = DDRC | B00001111; // sets Port C bits 0-3 to output
PORTC = PORTC | B00001111 ; // initialize all fans to off
Bit 0 = Master Bath Fan
Bit 1 = Powder Room Fan
Bit 2 = Basement Bath Fan
Bit 3 = Gym Fan and Damper
DDRC = DDRC & B11001111; // sets Port C bits 4-5 to input
Bit 4 = HRV ventillation on/off
Bit 5 = Temp Balancing Function on/off
digitalWrite(18, HIGH) ; // turn on the input pullup resistors
digitalWrite(19, HIGH) ;
delay(100) ; // Wait 0.1 seconds at start
blinker(150) ; // three quick blinks show cpu is OK
blinker(150) ;
blinker(150) ;
delay (100) ;
Serial.begin(9600) ;
Serial.println(ver) ; // send software version
Serial.println(chan1) ;
Serial.println(chan2) ;
Serial.println(" ") ;
// -------------End of Setup---------------
do {
// check_clocks() ;
blinker(50) ;
loop_start is 16 bits. It’s max value is 65536. millis returns 32 bits. Its max value is much bigger.
This means that millis()<loop_start will always be > 2000 once the real time hits 67.5 seconds.
To fix: always use unsigned long or uint32_t for timing.
Other fix: truncate the value of millis()
if(((unsigned int)millis()) - loop_start > 2000)
This allows you to time small intervals without having to hold a full four bytes. Not usually a problem, but if it ever is - this is how you deal with it.
Oh, and I always like to suffix my variable names with unit of measure: loop_start_ms or loop_start_us if I am using micros().
If there is a fixed time interval, as in this case, and the app will run 24/7/ 365 wouldn’t using software defined time work better?
For example using “for” loop ?
Assuming accuracy is not an issue of course.
Of course there are other options - hardware timers , WDT.
Millis and micros are pretty accurate ways to do this with a few micros/millis seconds accuracy due to testing and looping. Assuming your loop is fast of course
If you need sub micro second accuracy, the standard 328 or 2560 arduinos are not the right platform.
If you want to do an active wait, then delay and delaymicrosecond are good tools. I suggest studying the code of delaymicrosecond to see how at the core of the function they use asssembly language level understanding of what time instructions are taking to generate the right delay
millis() is not highly accurate, note, it will sometimes jump by 2 units, not 1. micros() is as
accurate as software can be though.
delayMicroseconds (n) doesn't work if the value of n is too large, and this often catches people out,
I would suggest not trying to pass it a value larger than 8000 to be on the safe side (currently I think
the fail point is 16384, on Uno and many other boards, but best to check).
julyjim:
If there is a fixed time interval, as in this case, and the app will run 24/7/ 365 wouldn't using software defined time work better?
For example using "for" loop ?
What does the arduino do between loops? Well - it looks at the USB connections and checks for a new sketch coming down the pipe. You can write a loop that doesn't terminate, you can write your own main(), but my understanding is that if you do, you'll need to reset to upload a new sketch. It may also do other things during that pause that are important.
PaulMurrayCbr:
int main(void)
init();
initVariant();
#if defined(USBCON)
USBDevice.attach();
#endif
setup();
for (;;) {
loop();
if (serialEventRun) serialEventRun();
return 0;
So if you don't ever return from loop() run the only thing you miss is that idiotic serialEventRun() thing which boils down to something like:
if (Serial.available()) {
serialEvent();
Don't ask me why Arduino considered that to be an improvement over just putting that code in your sketch, it's less beginner friendly, and slows down/wastes memory on the 99.99% of sketches that don't use serialEvent().
On the AVR boards, sketch upload is initiated by the USB-serial chip pulling the MCU's reset line low(or a serial port being opened/closed at 1200 baud on the ATmega32U4 boards), which causes the bootloader to run, there's no need for the MCU to monitor for an upload while the user's application is running and not returning from loop() will have no effect on your ability to upload sketches.
Jim
I assumed, wrongly as always, the outcome of the OP was overflowing variable.
That is often overlooked in types of apps I also specified.
Not sure how timing accuracy became an issue and "for" loop got interpreted as Arduino loop function.
Sorry to be bother.
Jim
