Do multiple task on Arduino Mega
Hi everybody, I'm trying to run multiple task on my Arduino Mega board, in order to accomplish indoor pedestrian localization. I've got an Adafruit 10-DOF IMU useful to acquire acceleration and gyroscope data. I would like to read data at 100Hz frequency (100 sample/sec) and the processing data all inside my board. Here's my application logic:
/*... some init variables ...*/
void processingAlgorithm(v_accx, v_accy, v_accz, v_gyrox, v_gyroy, v_gyroz, timer){
  /* some code here */
    /* Sensors initialisation */
  if (!accel.begin()){
    Serial.print("Error during accelerometer initialisation");
    while (1);
  if (!mag.begin()){
    Serial.print("Error during magnetometer initialisation");
    while (1);
  if (!bmp.begin()){
    Serial.print("Error during bmp initialisation");
    while (1);
  if (!gyro.begin()){
    Serial.print("Error during gyroscope initialisation");
    while (1);
void loop(){
 /* Get a new sensor event */
  sensors_event_t event;
  /* Display the results (acceleration is measured in m/s^2) */
  accel.getEvent(&event);
  /* Display the results (gyroscope values in rad/s) */
  gyro.getEvent(&event);
  v_accx(index) = event.acceleration.x;
  v_accy(index) = event.acceleration.y;
  v_accz(index) = event.acceleration.z;
  v_gyrox(index) = event.gyro.x;
  v_gyroy(index) = event.gyro.y;
  v_gyroz(index) = event.gyro.z;
  timer(index) =  millis()*0.001;
  if(indice == 100){
    processingAlgorithm(v_accx, v_accy, v_accz, v_gyrox, v_gyroy, v_gyroz, timer);
  }else{
    index = index+1;
I think my logic is wrong, because I'm not able to acquire at 100Hz and I don't know why. Hope someone will help. Thank you. Giacomo.
// some answer here in the event of seeing more details
Here my full processing algorithm, in order to give you so much more details.
void processingAlgorithm(const Eigen::RowVectorXd& v_accx, const Eigen::RowVectorXd& v_accy, const Eigen::RowVectorXd& v_accz, const Eigen::RowVectorXd& v_gyrox, const Eigen::RowVectorXd& v_gyroy, const Eigen::RowVectorXd& v_gyroz,const Eigen::RowVectorXd& timer){
  /* Gyroscope bias, to be determined for each sensor */
  Vector3d gyro_bias;
  gyro_bias << -0.0156,
               -0.0101,
               -0.0020;
  /* gravity */
  double gravity = 9.8000;
  /* gravity vector */
  Vector3d g;
  g << 0,
       0,
       gravity;
  /* gyroscope stance phase detection threshold */
  double gyro_threshold = 0.6;
  /* Orientation from accelerometers. Sensor is assumed to be stationary */
  pitch = -asin(v_accx(0)/gravity);
  roll = atan(v_accy(0) / v_accz(0));
  yaw = 0;
  //Orientation matrix C initialization
  Matrix3d C;
  C << cos(pitch)*cos(yaw), (sin(roll)*sin(pitch)*cos(yaw))-(cos(roll)*sin(yaw)), ((cos(roll)*sin(pitch)*cos(yaw)) + (sin(roll)*sin(yaw))),
       cos(pitch)*sin(yaw), (sin(roll)*sin(pitch)*sin(yaw)) + (cos(roll)*cos(yaw)), (cos(roll)*sin(pitch)*sin(yaw)) - (sin(roll)*cos(yaw)),
      -sin(pitch), sin(roll)*cos(pitch), cos(roll)*cos(pitch);
  Matrix3d C_prev(3,3);
  C_prev = C;
  /* Accelerations in sensor frame */
  MatrixXd acc_s(3,data_size);
  acc_s = MatrixXd::Zero(3,data_size);
  acc_s << v_accx,
           v_accy,
           v_accz;
  /* Rates of turn in sensor frame */
  MatrixXd gyros(3, data_size);
  gyros << v_gyrox,
           v_gyroy,
           v_gyroz;
  /* Preallocate storage for accelerations in navigation frame */
  MatrixXd acc_n(3,data_size);
  acc_n = MatrixXd::Zero(3,data_size);
  acc_n.col(0) = C*acc_s.col(0);
  /* Error covariance matrix */
  MatrixXd P(9,9);
  P = MatrixXd::Zero(9,9);
  /* Process noise parameter, gyroscope and accelerometer noise */
  double sigma_omega = 1 * pow(10, -2);
  double sigma_a = 1 * pow(10, -2);
  /* ZUPT measurement matrix */
  MatrixXd H(3,9);
  H << 0, 0, 0, 0, 0, 0, 1, 0, 0,
       0, 0, 0, 0, 0, 0, 0, 1, 0,
       0, 0, 0, 0, 0, 0, 0, 0, 1;
  /* ZUPT measurement noise covariance matrix */
  double sigma_v = 1 * pow(10, -2);
  Matrix3d R(3, 3);
  R << sigma_v, 0, 0,
       0, sigma_v, 0,
       0, 0, sigma_v;
  Matrix3d R1(3, 3);
  R1 = R * R;
  R = R1;
  /************* MAIN LOOP *************/
  for (int t = 1; t < data_size; t++) {
    /******* Starts INS (trasformation, double integration) *******/
    float dt = timer(t) - timer(t-1);
    Serial.println("Il dt è:"+String(dt));
    /* Remove bias from gyro measurements */
    VectorXd gyro_s1(3);
    gyro_s1 << gyros.col(t) - gyro_bias;
    /* Skew-symmetric matrix for angular rates */
    Matrix3d ang_rate_matrix(3, 3);
    ang_rate_matrix << 0, -gyro_s1(2), gyro_s1(1),
                       gyro_s1(2), 0, -gyro_s1(0),
                       -gyro_s1(1), gyro_s1(0), 0;
    /* Identity Matrix (3x3) - (9x9) */
    Matrix3d identity_3;
    identity_3 = MatrixXd::Identity(3,3);
    Matrix3d identity_9;
    identity_9 = MatrixXd::Identity(9,9);
    /* Orientation estimation */
    Matrix3d numeratore;
    numeratore = C_prev*((2*identity_3)+(ang_rate_matrix*dt));
    Matrix3d denominatore;
    denominatore = ((2*identity_3)-(ang_rate_matrix*dt));
    C = (numeratore) * (denominatore.inverse());
    /* Traforming the acceleration from sensor frame to navigation frame */
    acc_n.col(t) = 0.5 *(C+C_prev) * acc_s.col(t);
    /* Velocity and position estimation using trapeze integration */
    vel_n.col(t) = vel_n.col(t-1) + (((acc_n.col(t) - g) + (acc_n.col(t-1) - g))*(dt/2));
    pos_n.col(t) = pos_n.col(t-1) + (vel_n.col(t)+vel_n.col(t-1))*dt/2;
    /* State transition matrix */
    MatrixXd Fi(9, 9);
    Fi << 1, 0, 0, 0, 0, 0, 0, 0, 0,
          0, 1, 0, 0, 0, 0, 0, 0, 0,
          0, 0, 1, 0, 0, 0, 0, 0, 0,
          0, 0, 0, 1, 0, 0, dt, 0, 0,
          0, 0, 0, 0, 1, 0, 0, dt, 0,
          0, 0, 0, 0, 0, 1, 0, 0, dt,
          0, -dt*(-acc_n(2,t)), -dt*(acc_n(1,t)), 0, 0, 0, 1, 0, 0,
          -dt*(acc_n(2,t)), 0, -dt*(-acc_n(0,t)), 0, 0, 0, 0, 1, 0,
          -dt*(-acc_n(1,t)), -dt*(acc_n(0,t)), 0, 0, 0, 0, 0, 0, 1;
    MatrixXd FT(9,9);
    FT = Fi.transpose();
    /* Compute the process noise covariance Q */
    MatrixXd Q(9,9);
    Q << pow(sigma_omega*dt,2),0,0,0,0,0,0,0,0,
         0,pow(sigma_omega*dt,2),0,0,0,0,0,0,0,
         0,0,pow(sigma_omega*dt,2),0,0,0,0,0,0,
         0,0,0,0,0,0,0,0,0,
         0,0,0,0,0,0,0,0,0,
         0,0,0,0,0,0,0,0,0,
         0,0,0,0,0,0,pow(sigma_a*dt,2),0,0,
         0,0,0,0,0,0,0,pow(sigma_a*dt,2),0,
         0,0,0,0,0,0,0,0,pow(sigma_a*dt,2);
    /* Propagate the error covariance matrix */
    MatrixXd P_temp1(9,9);
    P_temp1 = multiplication(Fi,P);
    MatrixXd P_temp2(9,9);
    P_temp2 = multiplication(P_temp1,FT);
    P = P_temp2 + Q;
    /******* END INS *******/
    /* Stance phase detection and zero velocity updates */
    float norm = gyros.col(t).norm();
    if (norm < gyro_threshold) {
      /* Start Kalman filter zero-velocity update */
      /* Kalman gain */
      MatrixXd K_temp1(9,3);
      K_temp1 = multiplication(P,H.transpose());
      MatrixXd K_temp2(3,9);
      K_temp2 = multiplication(H,P);
      Matrix3d K_temp3;
      K_temp3 = multiplication(K_temp2,H.transpose());
      Matrix3d K_temp4;
      K_temp4 = K_temp3 + R;
      Matrix3d K_temp5;
      K_temp5 = K_temp4.inverse();
      MatrixXd K(9,3);
      K = multiplication(K_temp1,K_temp5);
      /* Update the filter state */
      VectorXd delta_x(9);
      delta_x = multiplication(K,vel_n.col(t));
      /* Update the error covariance matrix */
      MatrixXd P2_temp1(9,9);
      P2_temp1 = multiplication(K,H);
      MatrixXd P2_temp2(9,9);
      P2_temp2 = identity_9 - P2_temp1;
      P = multiplication(P2_temp2,P);
      /* Extract errors from KF state */
      Vector3d attitude_error;
      attitude_error << delta_x(0),
                        delta_x(1),
                        delta_x(2);
      Vector3d pos_error;
      pos_error << delta_x(3),
                   delta_x(4),
                   delta_x(5);
      Vector3d vel_error;
      vel_error  << delta_x(6),
                    delta_x(7),
                    delta_x(8);
      /* End Kalman filter zero-velocity update */
      /* Apply corrections to INS estimates */
      /* Skew-symmetric matrix for small angles to correct orientation */
      Matrix3d ang_matrix;
      ang_matrix <<  0, attitude_error(2), -attitude_error(1),
                    -attitude_error(2), 0, attitude_error(0),
                     attitude_error(1), -attitude_error(0), 0;
      /* Correct orientation */
      Matrix3d C_part1;
      C_part1 = (2 * identity_3) + ang_matrix;
      Matrix3d C_part2;
      C_part2 = (2 * identity_3) - ang_matrix;
      Matrix3d C_part3;
      C_part3 = C_part1 * C_part2.inverse();
      C = C_part3 * C;
      /* Correct position and velocity base on Kalman error estimates */
      vel_n.col(t) = vel_n.col(t) - vel_error;
      pos_n.col(t) = pos_n.col(t) - pos_error;
    C_prev = C; /* Save orientation estimate, required at start of main loop */
    /* Compute horizontal distance */
    float dis_temp1 = (pos_n(0,t)-pos_n(0,t-1));
    float dis_temp2 = (pos_n(1,t)-pos_n(1,t-1));
    distance(0,t) = distance(0,t-1) + sqrt(pow(dis_temp1,2)+pow(dis_temp2,2));
  Serial.println("Pos_n:");
  print_mat(pos_n);
  Serial.println("Distance:");
  print_mat(distance);
  Serial.println("Finita iterazione");
I'm pretty sure that won't compile.
That could be limiting.
Please post the entire program so we can see everything that you can see.
What multiple tasks are you trying to run ?
...R
