Do the Nano 5V and Mini Pro 5V have different rated and maximum current specs?
Looks like I'm being told. Do you mean for all servos and all Arduinos? I just have 1 9g servo, 2 LEDs and 1 PIR sensor. The circuit works for the nano but not for the pro mini. I'm wondering why not because they both use the ATMEGA328 chip. Note that I removed the regulator on the pro mini. I thought the nano was the same thing as the pro mini except for the USB port, making the nano able to pass less current from external components because the USB port requires some current. I was hoping to use the mini so that the sleep mode uses less current due to the lack of USB port.
