I followed the tutorial here:
http://www.mindkits.co.nz/mindkits-news-and-blog/arduino-energy-monitor
I setup up my circuit for use with 5V (33 ohm burden resistor). The CT sensor I am using is the SCT-013-000 (the 100 amp model).
Below is the basic sketch I am using, I am trying to monitor stuff on a 120 VAC line.
#include "EmonLib.h" // Include Emon Library
EnergyMonitor emon1; // Create an instance
emon1.current(1, 111.1); // Current: input pin, calibration.
double Irms = emon1.calcIrms(1480); // Calculate Irms only
Serial.print(" Apparent Power: ");
Serial.print(Irms*120.0); // Apparent power
Serial.print(" IRMS: ");
Serial.println(Irms);
With nothing encapsulated by the CT, or when there is no load I get readings like this:
Apparent Power: 27.19 IRMS: 0.23
Apparent Power: 27.16 IRMS: 0.23
Apparent Power: 27.46 IRMS: 0.23
Apparent Power: 27.15 IRMS: 0.23
Apparent Power: 27.47 IRMS: 0.23
Apparent Power: 27.39 IRMS: 0.23
Apparent Power: 27.32 IRMS: 0.23
Apparent Power: 27.27 IRMS: 0.23
Apparent Power: 27.35 IRMS: 0.23
Why do I get readings like this one its not monitoring a load?
These are readings I get from a lamp using a 60 WATT light bulb
Apparent Power: 137.31 IRMS: 1.14
Apparent Power: 101.34 IRMS: 0.84
Apparent Power: 100.75 IRMS: 0.84
Apparent Power: 101.18 IRMS: 0.84
Apparent Power: 102.22 IRMS: 0.85
Apparent Power: 102.91 IRMS: 0.86
Apparent Power: 101.24 IRMS: 0.84
Apparent Power: 101.12 IRMS: 0.84
How can I interpret the above data? I am new to this.
