Hi, I need some help. I am working on a volunteer project for my community. I thought I could do all of the programming myself but I can't figure out a part of it. I will try to explain what needs to happen. There are two switches, one is a safety the other is the one the person would press to complete an action. When the button is pressed I want pin 4 to go high, but only if the safety is low. I want pin 4 to stay high until the safety button is pressed.
I hope this is enough for you to help me, I know it is probably something really easy.
Thanks
This is the part of the code I am struggling with. I am not sure what the correct way to do this is. I might be totally in the wrong path with this code. What I want is when the leftstate button is pressed I want it to first check to make sure outstate is not pressed and then then make relayPin4 and 5 to go HIGH until oustate is pressed. This code is not doing what I want. In my project the outstate is a safety switch that stops a swinging arm going to the left. Outstate is just a small micro switch that the arm hits.
if (leftstate == HIGH) {
while (outstate == LOW) {
digitalWrite(relayPin4, LOW);
digitalWrite(relayPin5, LOW);
Suppose that leftState IS high, and that outState IS low. Why do you need to turn the pins off over and over?
You don't, so, let's revise the code:
{ // Down here where it belongs
Now, what is going to make the while loop end? Hell will freeze over first.
Outstate is on pin 9, if that is what you mean. I will show you my entire code the part that is at the very is the part I can't figure out, everything else is working.
// A1 = stop
// A2 = left
// A3 = right
// A4 = down
// A5 = up
// 8 = in safey
// 9 = out safety
// left = out
// right = in
const int Up = A5;
const int Down = A4;
const int Right = A3;
const int Left = A2;
const int Stop = A1;
const int inSafe = 8;
const int outSafe = 9;
const int relayPin1 = 0;
const int relayPin2 = 1;
const int relayPin3 = 2;
const int relayPin4 = 3;
const int relayPin5 = 4;
const int relayPin6 = 5;
const int relayPin7 = 6;
const int relayPin8 = 7;
int upstate = 0;
int downstate = 0;
int rightstate = 0;
int leftstate = 0;
int stopstate = 0;
int instate = 0;
int outstate = 0;
pinMode(Up, INPUT);
pinMode(Down, INPUT);
pinMode(Right, INPUT);
pinMode(Left, INPUT);
pinMode(Stop, INPUT);
pinMode(inSafe, INPUT);
pinMode(outSafe, INPUT);
pinMode(relayPin1, OUTPUT); // sets the digital pin as output
pinMode(relayPin2, OUTPUT); // sets the digital pin as output
pinMode(relayPin3, OUTPUT); // sets the digital pin as output
pinMode(relayPin4, OUTPUT); // sets the digital pin as output
pinMode(relayPin5, OUTPUT); // sets the digital pin as output
pinMode(relayPin6, OUTPUT); // sets the digital pin as output
pinMode(relayPin7, OUTPUT); // sets the digital pin as output
pinMode(relayPin8, OUTPUT); // sets the digital pin as output
digitalWrite(relayPin1, HIGH); // Prevents relays from starting up engaged
digitalWrite(relayPin2, HIGH); // Prevents relays from starting up engaged
digitalWrite(relayPin3, HIGH); // Prevents relays from starting up engaged
digitalWrite(relayPin4, HIGH); // Prevents relays from starting up engaged
digitalWrite(relayPin5, HIGH); // Prevents relays from starting up engaged
digitalWrite(relayPin6, HIGH); // Prevents relays from starting up engaged
digitalWrite(relayPin7, HIGH); // Prevents relays from starting up engaged
digitalWrite(relayPin8, HIGH); // Prevents relays from starting up engaged
void loop(){
upstate = digitalRead(Up);
downstate = digitalRead(Down);
rightstate = digitalRead(Right);
leftstate = digitalRead(Left);
stopstate = digitalRead(Stop);
instate = digitalRead(inSafe);
outstate = digitalRead(outSafe);
if (downstate == HIGH) {
digitalWrite(relayPin2, LOW);
delay(300);
digitalWrite(relayPin1, LOW);
delay(300);
if (stopstate == HIGH) { //Stops everything
digitalWrite(relayPin2, LOW); //Needs to include screen stop and arm stop
delay(300);
if (upstate == HIGH) { //Puts screen up
delay(300);
digitalWrite(relayPin3, LOW);
delay(300);
while (outstate == HIGH)
