Do we have a teardown() function on the same lines of setup() function
Greetings,
I am making a speedometer cum odometer using Arduino UNO, a 128*64 LCD and a reed switch for my motorbike.
My query is that do we have any kind of teardown() function in Arduino that I could override in my sketch to write some clean-up stuff like persisting odo reading to EEPROM?
Any other callback function that gets invoked immediately before Arduino is disconnected from power would also serve my purpose.
vikalpsetya:
How would it know until it was too late?
Short answer, nope.
An option would be to give the Arduino a (super) cap as backup and detect when the normal power is disconnected and run your function.
you could make a circular buffer in EEPROM and just write every mile.
I didn't do the math, but with a 24bit number you could put at least a million writes to EEPROM if you are leveling
That would be a neat trick. How would the program know that you were about to turn off the power ?
You could write your own "teardown()" function and invoke it with say a pushbutton. The function could control a relay or transistor that supplies power to the Arduino so could turn it off. You would, however, then need a mechanism to turn it on again.
What everyone else said. When - under what set of conditions - would such a teardown() function be invoked? Silicon ain't psychic.
It's psychotic.
