Good morning,
Im new in arduino and I am making a bike speedometer. I saw a video to get some help making it but he used IR sensor. IR sensors can be disturbed at sunlight so i decided to use hall sensor so it is more accurate. So, do I have to change anything in the code mentioned below?
#include <LiquidCrystal.h>
#include <TimerOne.h>
const int rs = 8, en = 3, d4 = 4, d5 = 5, d6 = 6, d7 = 7;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
const int IRSensorPin = 2;
const int ledPin = 13;
int inputState;
int lastInputState = LOW;
long lastDebounceTime = 0;
long debounceDelay = 5;
long time;
long endTime;
long startTime;
int RPM = 0;
double trip = 0;
double kkbanspd = 0.00223;
float lnTime = 0;
int spff = (RPM * kkbanspd) * 60;
void setup(void) {
pinMode(IRSensorPin, INPUT);
pinMode(ledPin, OUTPUT);
lcd.begin(16, 2);
lcd.clear();
lcd.print("Hive");
lcd.setCursor(0, 1);
lcd.print("Industries");
delay(2000);
endTime = 0;
Timer1.initialize(1000000); // Set the timer to 60 rpm, 1,000,000 microseconds (1 second)
Timer1.attachInterrupt(timerIsr); // Attach the service routine here
void loop(void) {
time = millis();
int currentSwitchState = digitalRead(IRSensorPin);
if (currentSwitchState != lastInputState) {
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
if (currentSwitchState != inputState) {
inputState = currentSwitchState;
if (inputState == LOW) {
digitalWrite(ledPin, LOW);
calculateRPM(); // Real RPM from sensor
else {
digitalWrite(ledPin, HIGH);
lastInputState = currentSwitchState;
void calculateRPM() {
startTime = lastDebounceTime;
lnTime = startTime - endTime;
RPM = 60000 / (startTime - endTime);
endTime = startTime;
trip++;
void timerIsr()
// Print RPM every second
// RPM based on timer
Serial.println("---------------");
time = millis() / 1000;
Serial.print(time);
Serial.print(" RPM: ");
Serial.println(RPM);
Serial.print(spff);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Spd:");
lcd.setCursor(5, 0);
lcd.print((RPM * kkbanspd) * 60);
lcd.setCursor(12, 0);
lcd.print("Km/h");
Serial.print((RPM * kkbanspd) * 60);
lcd.print("Trp:");
lcd.setCursor(5, 1);
lcd.print(trip * kkbanspd);
lcd.setCursor(12, 1);
lcd.print("Km");
RPM = 0;
Thanks in advance ![]()
