Hi guys,
I sm struggling with writing a page buffer for my program. Currently, the issue is with the do while loop, please could you help me to rewrite it so that it works?
Thanks Tom
#include <SPI.h>
#include <SandTimer.h>
#include <millisDelay.h>
#include <Adafruit_GPS.h> //Libraries
#define GPSSerial Serial
Adafruit_GPS GPS(&GPSSerial);
SandTimer timer1;
#define GPSECHO false
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
U8G2_SSD1309_128X64_NONAME2_2_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
uint32_t timer = millis();
const int chipSelect = 4;
float ms = 0; //Meters/Second variable
float avems = 0; //Average M/S variable
float mscounter = 0; //Speed total (for average)
int integcounter = 0; //Counts half-seconds
float meterstraveled = 0; //Total meters
int splittotal = 0; //Split total (in seconds) (Essential to be an integer)
int splitseconds = 0; //Seconds on split display (Essential to be an integer)
int splitminutes = 0; //Minutes on split display (Essential to be an integer)
int seconds = 0;
int minutes = 0;
int hours = 0; //Self-explanatory (for timers)
int splitaveragetotal = 0; //All split seconds added together (for average split)
int splitaverageseconds = 0; //Split average seconds
int splitaverageminutes = 0; //Split average minutes
int splitaverage = 0; //Split average
int splitaveragesecondsdisp = 0; //Display variables, fixes a bug
int splitaverageminutesdisp = 0;
float splitmdisp = 0;
float splitsdisp = 0; //Display Variables
int tc = 0; //Counter variable
int dp = 0; //Data-point variable
int dpave = 0; //Average of the data-points
int dprec = 0; //Counter variable
float knot = 0;//Speed in knots recorded from GPS
float aveknots = 0; //Speed in knots averaged over 1/2 second (equal to 1 data point and 5 knot readings)
int knotcounter = 0; //Counter variable
int sensorValue = analogRead(A3); //For the data write switch
float msfm = 0; //M/S for the meters calculation
millisDelay secdelay; //Timing delay (for timer)
void setup(void) {
float voltage = sensorValue * (5.0 / 1023.0); //Converts A3 reading into a 5v equivalent
Wire.begin();
Wire.setClock(400000L);
GPS.begin(9600);
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
GPS.sendCommand(PGCMD_ANTENNA);
delay(1000); //GPS initialization
u8g2.begin();
GPSSerial.println(PMTK_Q_RELEASE);
int realhours = GPS.hour - 8;
if (realhours < 0) {
realhours = realhours + 24; //For SD timestamp (24 hour format)
const char s[] PROGMEM = "Progmem";
const char s1[] PROGMEM = "ABC" ;
const char s2[] PROGMEM = "DEF" ;
const char s3[] PROGMEM = "GHI" ;
const char s4[] PROGMEM = "SMT" ;
const char *a[] = { s1, s2, s3, s4 };
void loop(void) {
u8g2.firstPage();
do {
if (secdelay.justFinished()) {
seconds++; //Checks if 1 second has passed, updates seconds variable
secdelay.repeat();
if (seconds == 60) {
seconds = 0; //Checks if 60 seconds have passed, resets seconds, increases minutes
minutes++;
if (minutes == 60) {
minutes = 0; //Checks if 60 minutes have passed, resets minutes, increases hours
hours++;
char c = GPS.read();
if (GPSECHO)
if (c) Serial.print(c);
if (GPS.newNMEAreceived()) {
Serial.println(GPS.lastNMEA());
if (!GPS.parse(GPS.lastNMEA())); //Serial GPS info for debugging
if (timer > millis()) timer = millis(); //Restarts main timer
if (timer1.finished()) {
knot = knot + GPS.speed; knotcounter++;
timer1.startOver();
if (millis() - timer > 500) { //Runs every half-second (responsible for screen-flicker)
timer = millis(); // Resets timer
if (GPS.fix) {
aveknots = knot / knotcounter;
Serial.println(aveknots);
ms = (aveknots * 0.5144444); //Converts knots to meters/second
Serial.println(ms);
knot = 0;
tc = 0;
knotcounter = 0;
aveknots = 0;
if (ms <= 0.75) {
u8g2.setFont(u8g2_font_courR08_tr); // choose a suitable font
u8g2.drawStr(0, 10, "Error: IDLE"); // write something to the internal memory
u8g2.drawStr(1, 10, "Battery: ");
u8g2.setCursor(1, 80);
u8g2.drawStr(2, 10, "Meters:");
u8g2.setCursor(2, 80);
u8g2.print(meterstraveled);
if (ms > 0.75)
msfm = ms;
mscounter = (mscounter + msfm); //Continually adds speed to total (for averages)
integcounter = (integcounter + 1); //Adds +1 to variable every half second (for averages)
avems = mscounter / integcounter; //Generates average meters/second (for total)
meterstraveled = avems * (integcounter / 2); //Calculates total (meters/second divided by seconds)
meterstraveled = round(meterstraveled);
splittotal = 500 / (ms); //Generates seconds per 500m
dp = dp + splittotal; //Adds data-points for dpave variable
dprec++;
if (dprec >= 6) {
dpave = dp / 6; //Calculates average
dprec = 0;
dp = 0; //Resets data-points and counter variable
splitminutes = dpave / 60; //Generates split minutes from split seconds
splitseconds = dpave - (splitminutes * 60); //Displays remaining seconds
splitaveragetotal = splitaveragetotal + splittotal; //All split times (in seconds) added together
splitaverage = splitaveragetotal / (integcounter); //Averages out split times w/ seconds
splitaverageminutes = splitaverage / 60; //Calculates split minutes
splitaverageseconds = splitaverage - splitaverageminutes * 60; //Calculates split seconds
splitaverageminutesdisp = splitaverageminutes;
splitaveragesecondsdisp = splitaverageseconds;
splitmdisp = splitminutes;
splitsdisp = splitseconds; //Display variables
u8g2.setFont(u8g2_font_courR08_tr); // choose a suitable font --------------------CHANGE THIS FONT TO SOMETHING LARGER
u8g2.drawStr(0, 10, "M:");
u8g2.setCursor(0, 25);
u8g2.drawStr(1, 10, "S:");
u8g2.setCursor(1, 25);
u8g2.print(splitmdisp);
u8g2.drawStr(1, 50, ":");
u8g2.setCursor(1, 75);
u8g2.print(splitsdisp); //adjust pixels to get a good display
} while ( u8g2.nextPage() );
errors:
C:\Users\User\OneDrive\Documents\Arduino\Page_buffer\Page_buffer.ino: In function 'void loop()':
Page_buffer:185:3: error: expected 'while' before '}' token
Page_buffer:185:3: error: expected '(' before '}' token
Page_buffer:185:3: error: expected primary-expression before '}' token
Page_buffer:185:3: error: expected ')' before '}' token
Page_buffer:185:3: error: expected ';' before '}' token
C:\Users\User\OneDrive\Documents\Arduino\Page_buffer\Page_buffer.ino: At global scope:
Page_buffer:186:1: error: expected declaration before '}' token
exit status 1
