Its because you put the while() inside the loop(). It really counts up to 9, but then it ends and the void loop begins from the start. The while() loop begins once again, but this time x = 9 and the while() executes only once. Then the process repeats and while() executes only once... To solve the problem use the while() in the setup(). It executes only once. And if you want to work with numvers < 255, use byte instead on int.
This perfectly illustrates a danger with the do-while, which is also it's useful feature ... it always runs at least one time. If you had coded it more conventionally as a while, you would have no problem.
int x = 0;
do {
delay(50);
Serial.println(x);
x = x+1;
while (x < 10);
// Add this line...
while(true);
