do-while problem
Hi all,
I am trying to set DS3231 clock with a 4x4 keypad using Arduino Mega.
What I am trying to achieve is, if I press the '' key from the 4x4 keypad than the Mega should ask for me to enter 2 key strokes, if either key equals to '#' it should break the do-while. Than it should convert these strokes to a 2 digit number by a simple calculation (x110 + x2). After that it should do a comparison. If this 2 digit number is equal to '0' than it shouldn't set the year.
If it's 17 or greater it would set the year with this number. And if it's smaller than 17 then this micro loop should repeat itself until desirable number comes out (0 or a number bigger than 17).
Below is my code, the do-while loop doesn't work as I expect and I am not sure what is wrong and also I am a newbie.
Thanks in advance.
#include <Wire.h>
#include <DS3231.h>
#include <Keypad.h>
const byte Satir = 4; //dört satır
const byte Sutun = 4; //dört sütun
char Tuslar[Satir][Sutun] = {
	{ '1','2','3','A' },
	{ '4','5','6','B' },
	{ '7','8','9','C' },
	{ '*','0','#','D' }
byte rowPins[Satir] = { 9, 8, 7, 6 }; //tuş takımının satır çıkışlarına bağla
byte colPins[Sutun] = { 5, 4, 3, 2 }; //tuş takımının sütun çıkışlarına bağla
Keypad TusTakimi = Keypad(makeKeymap(Tuslar), rowPins, colPins, Satir, Sutun);
int Yil;
int Ay;
int Gun;
int Sayi;
int SayiSonuc;
char Tus;
DS3231 clock;
RTCDateTime TarihZaman;
	clock.begin();
	TarihZaman = clock.getDateTime();
	Yil = TarihZaman.year;
	Ay = TarihZaman.month;
	Gun = TarihZaman.day;
	char Tus = TusTakimi.getKey();
	if (Tus == '*') {
		Serial.println("Tarih ayarlama modu, 2 basamak 'Yil' degerini girin. Vazgeçmek için '#' tuşuna basın."); [b]//year setting mode instructions[/b]
		do {
			SayiSonuc = TusGir();
		} while (SayiSonuc == 0 || SayiSonuc > 16); [b]//this comparison does not work[/b]
		if (SayiSonuc == 0) {
		else {
			Yil = SayiSonuc + 2000;
// serial print the year every second
	if (MevcutZaman - EskiSaniye > 1000) {
		Serial.print(TarihZaman.year);
Serial.print(" ");
EskiSaniye = MevcutZaman;
	MevcutZaman = millis();
int TusGir() {
	// 1st digit
		int Tus1 = TusTakimi.getKey();
		while (Tus1 == NO_KEY) {
			switch (Tus1) {
			case '*': case 'A': case 'B': case 'C': case 'D':
				Serial.print("Hatalı giriş yaptınız. ");
			case '1': case '2': case '3': case '4': case '5': case '6': case '7': case '8': case '9':
				Tus1 = (Tus1 - '0');
			case '#':
		// 2nd digit
		int Tus2 = TusTakimi.getKey();
		while (Tus2 == NO_KEY) {
			switch (Tus2) {
				Tus2 = (Tus2 - '0');
			case '#':
		SayiSonuc = (Tus1 * 10) + Tus2; //number calculation
	return SayiSonuc;
Thanks, I solved the problem.
