I am reading an RTC that controls a stepper driven clock and I want to pause the clock at a given time.
As a test run, I have the program set to loop out of the 'move hands' routine when the RTC reads 20 seconds. This works fine.
I want the hands to start moving again at 30 seconds.
I have tried the following but it just sticks in an endless loop with the seconds advancing beyond 30
do { //read RTC}
Serial.print(second);
while (second <= 30);
That's because your while clause is in the wrong place.
A do/while statement is fairly rare. A while statement is far more common. Unless you understand the difference, and have a good reason for using do/while, use while.
do { //read RTC}
Inside of that loop you do not actually read the RTC.
Unless an interrupt sets the value of "second", second will not change.
You want the do-while loop here. It lets you read the RTC before making the while() compare. If you use a while loop, you need to make a read before the while loop and a read inside of it as well.
do
static unsigned long lastSecond;
second = some.kind.of.read RTC;
if ( second > lastSecond ) // keep from printing the same seconds over and over, keep from overflowing the serial output buffer
lastSecond = second;
} while (second <= 30);
PaulS:
You got it to be kidding, right?
Yet another nonsense , offensive to recipient " Unless you understand the difference" , and unsubstantiated , "advise".
Perfect example for "do {process} while" is to guarantee at lest ONE pass thru the process.
And the one pass may be one too many. There is nothing that a do/while can do that a while can't do, and the while will be sure to NOT iterate at all, if doing so is inappropriate.
The do while loop was fine, but just had a syntax error. Idk what the first kid was talking about. Using the while loop, it will only loop to 29 anyway.
B1Gtone:
Please explain?
If I dont put "int second;" then the compiler says "second was not declared in this scope"
Because you are trying to read second before you declare it, simply move the byte.... line outside the while loop.
Try rewriting the same do loop you had at the top, moving the while loop to the end (like the stuff I have) and moving the byte line above the do while loop.
This reads the RTC and outputs the time to serial.print
The time reads and advances correctly but the seconds advance past 30 without exiting the while loop
You declare second as an int and then as a byte.
Which one is the RTC read stuffing data into?
Which one is being compared to 30?
