system
August 30, 2008, 8:02am
#1
I have no idea what this device is called, but I think it would be perfect for my project.
It’s a physical input device with a dial that goes from 0-9, and has two push buttons (one turns dial up 1, other turns it down 1)
I can draw it, if I didn’t explain it well enough.
Thanks!
westfw
August 30, 2008, 8:34am
#2
BCD rotary pushbutton switch Sometimes (usually?) a subset of “thumbwheel switches.”
Alas, like the above, these usually come in 0-7 or 0-F outputs, since their primary use was device select on SCSI peripherals.
It looks like digikey has some that have the full decimal outputs (grouped with their thumbwheel switches.) Here’s another one
system
August 30, 2008, 8:43am
#3
That’s it!
Thanks a bunch, exactly what I was thinking of!
system
August 30, 2008, 9:36pm
#4
The August edition of Nuts & Volts has a tutorial on the pushbutton rotary encoder on page 52. It uses a pic micro but the lesson is still relevant. Only 2 days till the next edition but you might still be able to get one. Just a heads up.
system
August 31, 2008, 5:50am
#5
Thanks for the heads up.
It took some creative googleing, but I was able to find an explanation on another forum Read a BCD value (Thumbwheel Switch)
I will grab that issue of nuts & volts anyway, can never have to much info!
system
August 31, 2008, 2:14pm
#6
Just stumbled onto this page http://www.arduino.cc/playground/Main/RotaryEncoders
I did not read through it yet though.
westfw
August 31, 2008, 9:02pm
#7
A “rotary encoder” is NOT usually the same things as a BCD encoded rotary switch…
