My name is Andrea and I am relatively new to Arduino and electronics.
Also I am new to the forum, so forgive me if my question is not structured as it should.
I am trying to create a laser based game using few electrical components.
For the purpose of this circuit I am using the following components:
2 X 5V Servo Motors
1 X 5V Thumb JoyStick
2 X 3V 532nm laser modules
Only one laser at the time will be on. Servos instead, are required to work together.
I was wondering if you find anything wrong with the schematic before my attempt in building it.
Also do you think that each servo needs a capacitor to smooth the signal?
andy-hgames:
The main problem is that it's not a schematic. It's a Fritzing spaghetti diagram. A schematic would actually be readable.
One thing I do notice is the absence of resistors connected to the MOSFETs. One between pin and gate (to protect the pin); one between pin and GND (to keep the MOSFET off when the pin is set to input mode).
What's the use of the 12V power supply, other than stressing out the on-board regulator of your Nano? You have a 5V supply already. Can't imagine it doesn't have a few mA spare to power your Arduino as well.
One more suggestion for the MOSFET. FQP30N50L.
Logic level and very low on resistance (35 milliOhms at 5V gate).
Here is the MOSFET circuit with the resistors that wvmarle mentioned. Ignore the transistor part number. It is an old 5A device. Better the newer ones mentioned above.
wvmarle:
Yes, I found it easier at the beginning to wire things up. Will definitely look into schematics.
wvmarle:
I will add the resistors, thanks for the advice.
wvmarle:
I will use the same power supply for another part of the circuit which deals with led targets and photoresistors; but yes will definitely have some spare current for the board. Thanks for the tip.
groundFungus:
Thanks a lot for the clarification.
I will buy the correct MOSFET and add the resistors to both protect the pin and act as pull down.
wvmarle:
I do assume that 5V supply is properly regulated of course...
And no problem with the USB uploads.
Thanks!
I am thinking of using a usb cable which goes from the 5V power supply to the actual usb female of the board.
This will reduce the risk of damaging the board.
I tested it already, I get 4.65V out of the 5V pin. I believe the board works well enough with this voltage.
Correct me if I am wrong.
It should work, but there may be another diode drop, not sure. You will lose some of the voltage you need to gate the mosfets, so it all depends on what you choose. There are logic level Mosfets that will trigger from 1-2.5V... suggest you search for something like that with the lowest Rds possible. Also the gate and pull downs are necessary, you can't have them floating. R2 can be even higher value to make it more efficient.
The 3V laser assemblies - are these bare laser diodes or complete modules with their own constant-current regulation?
Its best to post full information on every piece of hardware you reference, ie datasheets or product links, or we'll just have to keep asking you questions about it, such as:
What servos? What is their peak current demand?
What is the peak current demand of the last modules? What modules?
groundFungus:
The mosfet suggestion and diagram are excellent. Just for the record, the IRL540 will work just as well.
MarkT:
Thanks for the suggestion.
Yes the lasers have their on module to regulate the current.
I will soon update the post with full specifications.
