I wanted to better understand the byte data type, but the documentation actually confused me more and offered very little useful information.
https://www.arduino.cc/en/Reference/Byte
byte
DescriptionA byte stores an 8-bit unsigned number, from 0 to 255.
Example
byte b = B10010; // "B" is the binary formatter (B10010 = 18 decimal)
Does the 8-bit unsigned number from 0-255 HAVE to be in binary? If so, let's make that clear. Why not have the description show a range in binary and then in parenthesis include the 0-255? For example:
A byte stores an 8-bit unsigned number in binary form, from 0 to 11111111 (0 to 255)
Perhaps it is redundant to say 8-bit and binary in the same sentence, but it is certainly more clear for those of us who are still learning.
If it does not have to be in binary, why only show an example in binary? (at this point I'm assuming it does) Also, WHY did you include the comment using a variable "b" and then describe the "B" in the value? I understand that b and B are different, but I'm not as unfamiliar with programming as some people. How about we change that to:
byte ExampleVariable = B10010; // "B" in front of the binary number is required and indicates that the following number is in binary and not decimal form. (10010 = 18 in decimal form)
"(B10010 = 18 decimal)" really confused me for a bit. I know binary is only composed of 1s and 0s, so to see a B in the explanation really threw me for a loop. I know that's why you explained the "B" as being the binary formatter, but it wasn't clear at first glance. I suppose I am mostly confused by this explanation. If the byte MUST be binary, why do we have to use "B"? This is why I thought it might not have to be in binary. Another couple examples would really help as well.
Anyway, I think my explanation is becoming unclear as well. Assuming this is correct, can we just change it to this:
Description
Example
byte FirstExampleVariable = B10010; // "B" in front of the binary number is required and indicates that the following number is in binary and not decimal form. (10010 in binary = 18 in decimal form)
byte SecondExampleVariable = B0; // (0 in binary = 0 in decimal form)
byte LastExampleVariable = B11111111; // (11111111 in binary = 255 in decimal form)
After all, it is the learners, like myself, who read these things. The documentation should be extremely clear, provide plenty of examples, and at times be redundant. Again, I came here because I'm unsure of how a byte works. If I'm wrong on any of this, that's fine, please correct my mistakes, but also please make some improvements.
