does 5v 8mhz arduino work out of the box?
Hi again all,
I have made an arduino clone at 5v, and have run out of 16mhz resonators, so I picked a 8mhz one instead. I can program it, the sketch seems to work, except I get garbled serial output. Can this be related to the frequency and voltage? I have programmed it as a lilypad, since it's 8mhz, but does the voltage interfere here?
Joachim
No it's just the frequency. The lilypad runs on a lower voltage and that means it can't run at 16Mz so they run it at 8MHz. However the bootloader is different.
Yes you will.
Thanks Grumpy,
Aha, is that because the 328 is programmed as an arduino and used as a lilypad? Is that why the serial output is garbled?
Joachim
It will run at half the speed calculated for UART; the voltage is irrelevant (well, the AVR does not clock up to 16 MHz at 3,3V, but that's not your problem). You can adjust the code for that.
