Does a bunch of potentiometer controller need external power?
x20 pot 10kΩ
for arduino uno r3?
Not sure what your question is...
... but a potentiometer is usually connected between common (with the Arduino) GND and a voltage supply... so yes, you need something to supply the voltage.
Does that mean 20 pots at the same time? Then you'll need a multiplexer.
The total current then will be 20*0.5=10mA, should not be a problem when powered from the Uno.
In any case an ADC (of the Uno...) and pots should be powered from the same supply for ratiometric (voltage independent) analog reading.
You do have to think what you will do with all that data that is available to that poor little microprocessor.
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for advice on (nor for problems with) your project.
Find the parallel resistance of all your pots -
Then calculate current draw of the equivalent resistor - E=IR
Don't forget to take into consideration any other devices connected to the power supply - LEDs, displays, etc.
