For my project, I need to measure the force of a push of a finger/body part. Does a force-sensing BUTTON exist?
I've tried a FSR (force resistive sensor; Overview | Force Sensitive Resistor (FSR) | Adafruit Learning System) but it doesn't really work so well for my application because it's design seems better to measure pinches than pushes (you really need to be applying pressure from both sides).
Dave, thanks for the reply. Whether it's actually measuring force or measuring distance the button is pressed is less relevant to my application than simply: "when i push harder on this button, does it register a greater number?"
seanahrens:
I don't think that's the case. From the point of view of the sensor, it doesn't make any difference whether you're pinching it from both sides, or pushing on one side with the other side being reacted against a fixed object. Perhaps you just aren't pushing hard enough to operate the sensor. Can you give some idea of the maximum amount of force you want to measure?
seanahrens:
I've tried a FSR (force resistive sensor) but it doesn't really work so well for my application because it's design seems better to measure pinches than pushes (you really need to be applying pressure from both sides).
I'm thinking you need to study up on Newton's laws of force and motion.
It's simple. You mount it on something firm; the table for a start. If it then is not sufficiently sensitive, you just need to select the model that is; there is a whole range of them (somewhere!).
