Does a MOSFET H-bridge need a flyback diode to drive a relay?
I am using a TB6612 H-bridge module (here) to drive a 12v relay that has a 400-ohm coil.
Do I need to add a flyback diode across the relay coil, or can I rely on the body diodes of the MOSFETs in the H-bridge?
[The reason I am using the TB6612 is because I designed a board with several TB6612s, and was thinking I would employ an unused output of the board rather than build a separate transistor driver.]
I would add the flyback across the coil, assuming you use one half of the H-bridge in series with the coil.
Most people do.
The internal diodes suffice.
Compare to a relay controlled motor circuit.
These diodes are the internal body diodes of each MOSFET.
Yes
Thanks for the answers!
