Before I start working on implementing my new nRF24L01+ transceivers, I need to make sure I can get two ATmega328p microcontrollers talking. Since I have been studying on the communications protocol that is SPI, I noticed that a timing method is sent from the master to each of the slaves on the SCK pin. Now, before anyone goes off on a tangent, I know why the timing is there, why it's important and I know of the difference between synchronous and asynchronous communication.
I digress. Back to the question.
If I have one ATmega328p uC in an Arduino using the built-in Pierce oscillator (xtal + filters) and the other uC is breadboarded and using its own internal oscillator for timing, would it still work? Do I need matching timing sources or is the lower sampling rate going to be my limiting factor?
I might be confusing some things but I know that the standard 16 MHz on the Arduino (master) might cause problems with the 8 MHz on the internally-oscillated uC (slave).
Could anyone with experience on this shine some light on my concerns?
Thanks folks.
