Does an absolute encoder only support SSI output?
The question is like stated in the header, "Does an absolute encoder only support SSI output?"
I need an absolute encoder for controlling a stepper motor, but using the SSI output is not an option.
I am therefore curious to know whether an absolute encoder with another output even exists, or if I have to use a signal converter.
Thanks in advance!
The answer to my own question was: No.
It is apparently possible to get a hold of an absolute encoder with an analogue interface.
There are absolute shaft encoders with direct digital output.
10 turn potentiometer?
This is an absolute encoder :- http://uk.farnell.com/bourns/eaw0j-b24-ae0128l/encoder-rotary/dp/9358234 it uses SPI.
