Does an IR LED on PWM need a Resistor?
Hi there, I am using an TX IR LED on Arduino Uno digital pin 3 PWM.
​Does the IR LED on PWM need a Resistor?​
I am looking for max range
Ardalan:
Any LED is a current driven device. The junction temperature goes up as the current increases and the internal resistance goes down, so It draws more current and quickly dies. The series resistor limits the current to the LED so the run away does not happen.
If you want max range, work on the receiving end.
Paul
Ardalan:
Yes.
On an Arduino UNO the minimum resistor value will be approx 82 Ohms giving around 40mA to drive the LED.
( 5V - 1.5VLED) /0.04 Apin max = 82 Ohms (nearest resistor value)
Yours,
TonyWilk
Thanks Tony!!
Why starve the LED with 40mA when it can handle 1000mA?
INTP:
Maybe because until you tell the OP which LED to use, the conditions under which it can handle 1A and a failsafe driver circuit to build, they are stuck with driving it directly from a pin.
Yours,
TonyWilk
Two IR LEDs in series, with e.g. a 47ohm CL resistor, might give you some more range.
Leo..
