I thought that writing to an analogue pin with analogWrite() cause either the output voltage to change to some n/255 * 5 volts or something akin to PWM but it seems to do neither.
So. What behaviour should I expect (if any) if I analogWrite() to an analogue pin?
No. analogWrite(uint8_t pin, int val) documented in the wiring_analog.c file of the IDE. It contains a lengthy switch case statement base on switch(digitalPinToTimer(pin))
and which terminates with
case NOT_ON_TIMER:
default:
if (val < 128) {
digitalWrite(pin, LOW);
digitalWrite(pin, HIGH);
Good catch there, he probably does. The pins marked as analogue input A0 to A6 can be used as normal digital inputs / outputs and are not PWM capable pins.
As you pointed out a PWM capable pin is normally marked with a ~ next to the pin number.
Here is an animated gif of PWM
I kind of agree with this comment about what happens on pins that do not support PWM.
I have done a few LCD libraries that have backlight dimming control.
But I won't use analogWrite() if the backlight control pin doesn't support PWM.
IMO, for backlight dimming control, the backlight should be on for any non zero dim value, instead of being off until the dim value is half way up to max.
IMO, analogWrite() as a very bad name for a function that does PWM.
These days it starts to get really confusing and messy since some MCUs actually support analog outputs.
Some chips actually have a digital-to-analog converter (DAC) as well as an ADC, and they usually group it with the "analog" pins, and support a true analog output.
For example, the Arduino Zero has the DAC on A0, and supports analogWrite() on that pin.
But for most AVR Arduinos, there is no real analog output, and PWM outputs are not available on the same pins that can do analog input.
