Does any SD modules work better with Due?
I like my Uno data logger but want more speed. I notice SD modules do not have a battery. I'm presuming I need the battery for RTC. Would the Uno SD shield work (it contains a battery)? It won't plug into Due, but it could be connected by wire. Any ideas?
Thanks Gerry
Gerry48: I like my Uno data logger but want more speed. I notice SD modules do not have a battery. I'm presuming I need the battery for RTC. Would the Uno SD shield work (it contains a battery)? It won't plug into Due, but it could be connected by wire. Any ideas?
Thanks Gerry
Hello Gerry,
RTC 'as is' works OK via Wire with Due. SD also works OK via SPI with Due but you have to use the SPI 3x2 connector as follows: UNO SCK -------- SCK D13 MISO ------- DO D12 MOSI ------- DI D11 CS --------- pin x D10
I haven't measure the data transmission rate it should be similar to UNO. Regards
-p
