does anybody have suggestion how to get the 1Msps on Due
Here is a simple code I tried but it is producing garbage. For example when I ground PIN A6. it should read 0 but some readings will produce values greater than 0 I do not know why. I am trying to read sensor with 3692 pixels.
int myArray[3692];
REG_ADC_MR = 0x10380180; // FREERUN
ADC -> ADC_CHER = 0x02; // enable ADC on pin A6, AD1
delay(1);
for (int i = 0; i < 3692; i++) {
while ((ADC->ADC_ISR & 0x02) == 0); // wait for conversion
myArray = ADC->ADC_CDR[1]; // read value A6, AD1
for (int i = 0; i < 3692; i++){
_ Serial.println(myArray*);_
_
}_
_
}*_
Post your code between code tags.
Your code do not compile : myArray = ADC->ADC_CDR[1]; And ADC samples at 1MSPS requires a PDC DMA to log data.
They guy who previously posted the code said that it was working. I am guessing that I might need DMA to collect the data. I have tested over the weeks all the examples I could find, nothing worked. People post codes which was never tested.
Would you know by chance the code ?
Reply #5 here
