This is an interesting sensor, if it actually works:
Here's where it gets really interesting - look at the pictures. Notice anything strange? Look at the wire - what does it look like?
If you guessed "speaker wire" - you are correct...maybe? Now - see this link:
Notice the reddit user name, and how the poster begins "Our company..." - so, it is likely that the poster is a representative of the company that makes AquaPlumb (I would dare to say the poster is the owner).
So - how does one use a piece of two-wire speaker cable to measure -any- liquid's level?
This seems to be a common question here on the Arduino forum - at least once a week we get someone asking how to measure a liquid using light, or ultrasound, or some other method. Well - here's a method - but seemingly proprietary; I don't know if it is protected by a patent or whatnot - but could it be reverse engineered?
Look at those pictures again - notice something else about cable? What are all of those dark-ish "lines" (or something) down the center of the length of cable - spaced evenly...?
According to the site, the liquid never touches the wires - so the wires won't corrode (the end is supposedly sealed, and they mention in the FAQ that you can cut the cable shorter, and re-calibrate - but you need to re-seal the end). Supposedly it works on any type of liquid (even olive oil) - so it doesn't appear to be measuring resistance or anything. However, the say you can't use it in flammable liquids...
Anyone have any ideas? What are the marks? Is it some kind of RF system? Does it have something to do with the difference in the speaker cable wire (the "silver" wire vs. the "copper" wire - is one aluminum and the other copper - I'm not sure what speaker cable is actually made of)?
I noticed that it has some kind of special "sensor box" that you hook the cable to, then that outputs the changing voltage for your system, I suppose. I'm just curious about this whole thing, and wanted to stir the pot a bit for those seeking a liquid level detection solution as well, and perhaps get people thinking about how this device actually works.
