I recently installed arduino on a new computer and I can’t seem to be able to compile any code. It keeps throwing this error code at me that I’ve never seen before.
Arduino: 1.6.0 (Windows 7), Board: "Arduino Uno"
/Arduino/hardware/tools/avr/avr/bin/ld.exe: error while loading shared libraries: ?: cannot open shared object file: No such file or directory
collect2: error: ld returned 127 exit status
Error compiling.
I have gone through into the libraries and made sure they are in the right locations and they all are. I’m just using an example code (Servo Knob function) that I know to work on a different computer and have used many times before. I have tried other sample/example codes that I know to work and it still throws the same error code at me. The Servo example code is below for reference.
Controlling a servo position using a potentiometer (variable resistor)
by Michal Rinott <http://people.interaction-ivrea.it/m.rinott>
modified on 8 Nov 2013
by Scott Fitzgerald
http://arduino.cc/en/Tutorial/Knob
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int potpin = 0; // analog pin used to connect the potentiometer
int val; // variable to read the value from the analog pin
myservo.attach(9); // attaches the servo on pin 9 to the servo object
val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
myservo.write(val); // sets the servo position according to the scaled value
delay(15); // waits for the servo to get there
Has anyone encountered this error before? How does one correct it? Any help would be much appreciated. Thank you!
