Does anyone recognise these connectors?
Some research leads me to believe that they are Molex connectors of some kind, but which ?
It is described as a
0.15" pitch 4-pin polarized connector.
This is the source of your image: https://www.adafruit.com/product/4767
Thanks
I know where I can buy the leads, what I am interested in is buying the connectors. In actual fact, what I would really like is a right angled connector that will fit the connector pins on the device, but I thought that I would keep it simple to start with
If it looks like a "JST" connector, and it smells like a "JST" connector, then it might be a real or a copy of a "JST" connector.
This is a similar JST connector: https://uk.rs-online.com/web/p/wire-housings-plugs/8201179/
However, the pin pitch is 3.96mm, that is 0.1559 inch.
There are 0.15" JST connectors (3.81mm), but I can't find that for this type of connector.
Can you measure the pin pitch ?
[ADDED] After looking at many pictures, the also look like certain Molex connectors. I think it is a copy of a Molex / JST type connector.
It certainly looks like the connector that you linked to
Even with a digital calliper measuring the pin pitch accurately is not easy, but I make it 4.15mm or 0.163 inches,
Could the 0.15" be just a name and it is 0.1559" for real ?
Then it is a more normal pin pitch.
I could not find connectors with the gray-ish plastic yet. Adafruit and Sparkfun have found them, so we should be able to find them as well :face_with_raised_eyebrow:
Do you have the pcb pins header ? Then you can measure a pin itself and measure the outside of 4 pins. Pitch = (outside - pin) / 3
With the inaccuracy taken into account, can you get as low as 3.96 mm ?
Each pin 1.12 mm
Outside to outside of 4 pins = 12.90
so, pitch = (12.90 - 1.12) / 3 which is 3.93
Close enough ! only 0.03 mm difference.
So it is a normal 3.96 mm pin pitch JST / Molex alike connector of gray plastic. Perhaps the JST VHR series in my link fits, perhaps the dimensions are also different.
Thanks for the the input
I will probably take a punt on buying a likely candidate
Back in the "olden days" I would have taken the connector and PCB with the header into an actual electronic component store and asked "have you got a connector like this ?". Happy days !
Take a look at this datasheed: https://www.farnell.com/datasheets/1658608.pdf
Thanks for the link
A what? :astonished:
Look like JST ( https://www.jaycar.com.au/connectors-kit-with-popular-jst-xhp-and-ph2-headers/p/PT4457?pos=2&queryId=40b01e2670024a85e12c89f3cf6a7354 ) with locking tab.
mick
