Does anyone use MKRZero?
I see that on this board there is an i2c port and then there are i2c pins separately mentioned on D11 and D12, when I connect two mkrZeros together with using the pins I can't get anything to happen with and without pullup resistors. Googling does not help!?!?!?! where is all the info? where is all the documentation?
Do I need to define separately whitch pins I use for i2c?
I miss the code you used in your post. Also missing is the wiring diagram of your setup. Without this information we cannot help you.
I believe that the only MKR Zero-specific documentation is here:
And general information about I2C here:
sender.ino (1.6 KB)
receiverLightSwitch.ino (1.5 KB)
Seems I had one line missing from sender setup, but that does not explain why receiver didn't get the first message and do stuff with that.
Wire.onReceive(receiveEvent); // function that executes whenever data is received from writer
wiring was done using Vcc pin for pullup voltage through 4k7ohm resistors D11@C1->D11@C2 and D12@C1->D12@C2 for comms according to image below
  1. please do not attach code but post it in thread using code tags
  2. your connection diagram shows A5 A4 pins? can’t really make it, are those I2C pins?
That image is for reference how I used the resistors. Wiring was done in MKRZero differently, namely using Vcc pin for pullup voltage through 4k7ohm resistors D11@C1->D11@C2 and D12@C1->D12@C2 for comms
Sender (C1)
#include <Wire.h>
int var;
  pinMode(LED_BUILTIN, OUTPUT); // Set onboard LED as an output
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(9600);  // start serial for output
  Wire.write("0"); // send order once to start ping ponging orders between C1 and C2
void receiveEvent(int howMany)
      char c = Wire.read(); // receive a character
        if(c == '1')
          var = 0;
            while (var < 10)
              digitalWrite(LED_BUILTIN, HIGH);  // turn the LED on (HIGH is the voltage level)or do something else
              delay(50);
              digitalWrite(LED_BUILTIN, LOW);   // turn the LED off by making the voltage LOW or do something else
              delay(50);
              var++;
            Wire.write("0"); // send order to blink LED in C2
          if(c == '0')
            var = 0;
            while (var < 3)
              delay(100);
              delay(100);
              var++;
           Wire.write("1"); // send order to blink LED  in C2
REceiver(C2)
#include <Wire.h>
int var; //init
  pinMode(LED_BUILTIN, OUTPUT); // Set LED_BUILTIN as an output
        if(c == '0')
          var = 0;
          while (var < 3)
              digitalWrite(LED_BUILTIN, HIGH);  // turn the LED_BUILTIN on (HIGH is the voltage level)or do something else
              delay(100);
              digitalWrite(LED_BUILTIN, LOW);   // turn the LED_BUILTIN off by making the voltage LOW or do something else
              delay(100);
              var++;
          Wire.write("1"); // send order to blink LED_BUILTIN  in C1
        if(c == '1')
          var = 0;
          while (var < 3)
              delay(100);
              delay(100);
              var++;
          Wire.write("0"); // send order to blink LED_BUILTIN  in C1
hmmm I had found some oversights in code and fixed em...to no avail
C1
#include <Wire.h>
int var;
  Wire.begin(1);        // join i2c bus (address optional for master)
            var = 0;
            while (var < 10)
              delay(50);
              delay(50);
              var++;
          Wire.beginTransmission(2); //send to master
          Wire.write("0"); // send order to blink LED_BUILTIN  in C2
          Wire.endTransmission(2);  //stop sending to master
        if(c == '1')
          var = 0;
            while (var < 10)
              delay(50);
              delay(50);
              var++;
          if(c == '0')
            var = 0;
            while (var < 3)
              delay(100);
              delay(100);
              var++;
          Wire.write("1"); // send order to blink LED_BUILTIN  in C2
C2
#include <Wire.h>
int var; //init
  Wire.begin(2);        // join i2c bus (address optional for master)
        if(c == '0')
          var = 0;
          while (var < 3)
              delay(100);
              delay(100);
              var++;
          Wire.beginTransmission(1); //send to master
          Wire.endTransmission(1);  //stop sending to master
        if(c == '1')
          var = 0;
          while (var < 3)
              delay(100);
              delay(100);
              var++;
Excuse me but both of your sketches are wrong.
The beginTransmission()/endTransmission() calls are for the master only. In the onReceive callback you must only get the data the master sent to you, you cannot send something actively back, the master controls the bus!
If the master wants data from the slave it uses the requestFrom() method and the slave implements the code in the onRequest callback. There you can only use the write() method, the callback should be fast (no calculations and such stuff) and it should write exactly that many bytes the master requested (that's why I2C communication always follows an exact protocol).
I2C is not a replacement for an UART communication! It's not bidirectional! The master dictates everything.
nice, something to try... thank you pylon :slight_smile:
