Does Arduino suports this Custom LCD?
Hi.. I'm working at a project where I'm gonna need to order a custom lcd and I found this factory.
http://www.alibaba.com/product-detail/Segment-custom-lcd-display-with-white_1999568967.html
Is arduino cabable to drive this LCD?
ANY idea, will be apreciated.
Thank you very much
Rodrigo
It has poor documentation, it only sayd it's 3.3V.
I'm gonn ask them.. of they do.. So Could be possible?
If you solve the 3.3V compatibility yes, but you'd have to create your own code library.
You're gonna need the datasheet for the driver chip they're using so you know which pins do what.
cabecinhas: Hi.. I'm working at a project where I'm gonna need to order a custom lcd
No idea.
I think the people to ask are the people who make the LCD.
I have found this one that comes with some info.
http://www.aliexpress.com/store/product/Free-shipping-COG-128x64-dots-graphic-LCD-display-module-wih-PCB/1239663_1829943133.html
Could anyone tell me if it can work with arduino ?
Depends. What controller is attached to the display?
Hi...
I need to ask them.
Which controllers are most Commons in arduino, then I could search by its controller
Tks a lot
You should be able to find supported drivers with this as a starting point:
http://playground.arduino.cc/Code/LCD
cabecinhas: Which controllers are most Commons in arduino, then I could search by its controller
It simply doesn't work that way.
If it's a bare LCD with "zebra stripe" connector then there is no "common controller".
Every LCD needs a custom PCB and controller chip. You're expected to provide that PCB yourself (or pay them to do it for you).
Bottom line: There is no way to buy that screen at that price and use it with an Arduino.
