Hello everybody,
Explanation:
For a recent project of mine, i want to read inputs from a rotary encoder with a relatively high precision (1000lmp/U) .
I need to read every pulse that passes throug the three inputs (A, B and the reference pulse).
the reference pulse is there to exactly know the position of the reader head, you can read this by reading the state of a wire, wich pulls high when the reader head passes through a specific place in the encoder.
Moving on:
when this reference pulse is triggered, i want to hear a buzzer when that reference pulse has been found and to make it hearable, i need to put a delay between when i start the buzzer and when i stop it.
I am using a hardware interrupt on pin 3 to read the A wire on the encoder wich reffers to a function where i store the pulses in a variable.
now for my question:
do these hardware interrupts pause the delay i set for the buzzer and actually pauses that delay to work on the function when the delay is active and if not, how can you make it work like that?
the line where i attach the interrupt is line 53
the line where the delay starts is on line 84
the function i reffer to when the A wire is changed to high starts on line 95
//schermcode
#include <TFT_HX8357.h> // Hardware-specific library
#include <Adafruit_GFX.h> // Core graphics
TFT_HX8357 tft = TFT_HX8357();
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define GRAY int(210/8*2048) + int(216/4*32)+ int(224/8)
// eind schermcode
#define CHA 3
#define CHB 4
#define CHR 2
#define CW_LED 13
#define CCW_LED 12
int statusled = 5;
int buzzer = 11;
volatile int i = 0;
volatile int master_count = 0; // universal count
volatile byte INTFLAG1 = 0; // interrupt status flag
volatile byte INTFLAG2 = 0; // interrupt status flag
volatile int mapmaster = 0;
int pulsecounter = 0;
int readyr = 0;
tft.begin();
pinMode(CHA, INPUT);
pinMode(CHB, INPUT);
tft.setRotation(1);
tft.fillScreen(WHITE);
tft.fillRect(10, 10, 460, 300, GRAY);
tft.setCursor(20, 20);
tft.setTextColor(YELLOW);
tft.setTextSize(2);
tft.setTextWrap(false);
tft.print("status: no reference.");
tft.setCursor(20, 40);
tft.print("turn counter clockwise.");
tft.setCursor(240, 60);
tft.setTextSize(3);
tft.print("pos: 0");
while(!digitalRead(CHR)){
i = i;
attachInterrupt(1, flag, RISING);
// interrupt 0 digital pin 3 positive edge trigger
if(INTFLAG1 == 1){
tft.setCursor(384, 60);
tft.setTextSize(3);
tft.fillRect(384, 60, 180, 22, GRAY);
tft.print(map(master_count, 0, 1000, 0, 360));
INTFLAG1 = 0;
} // end if
if(readyr == 1){
tft.setTextSize(2);
tft.setTextColor(GRAY);
tft.setTextColor(GREEN);
tft.print("status: found reference");
digitalWrite(buzzer, LOW);
analogWrite(buzzer, 120);
delay(200);
readyr = 2;
} // end loop
void flag() {
if(readyr >= 1){
INTFLAG1 = 1;
// add 1 to count for CW
if (digitalRead(CHA) && !digitalRead(CHB)) {
master_count++ ;
mapmaster = map(master_count, 0, 1000, 0, 360);
if(master_count >= 1000){
master_count = 1;
// subtract 1 from count for CCW
if (digitalRead(CHA) && digitalRead(CHB)) {
master_count-- ;
if(master_count <= 0){
master_count = 999;
if(readyr == 0 && master_count >= 50){
readyr = 1;
master_count = 0;
Thanks already
Inzywinki
pulsecounter-forum.ino (2.77 KB)
