Hi everyone
So I'm trying to use the internal EEPROM of UNO to save the state of some LEDs and I've decided to use bitWrite in order to use the write cycles of the EEPROM as efficiently as possible , I just want to know if it's worth the trouble of using bitWrite. The question is would bitWrite rewrite every single bit in a byte of EEPROM and only change the one that we want or can it specifically target the very bit that it needs to change?
Thank you
EDIT : Nevermind it was a weird mistake I was making my brain just didn't register for some time
Nevermind I wasn't understanding the exaple code that I got, now I do, this doesn't have anything to do with bitwrite itself, you'll have to use EEPROMwrite anyways so the byte is updated
bitWrite is basically a read modify write. Therefore if any bits change it has to write all of the bits. There are some processors that do it on a bit by bit basis for I/o and internal registers, but not all. None I know of do it to memory.
Why not use the EEPROMex library then just use the update command, if nothing changes no writes take place.
Good Luck & Have Fun!
Gil
