Hi.
I am trying to make a 5v Arduino speedometer for a bicycle. It is powered by a dynamo, that provides dc output.
As I am powering it with a dynamo, I know that the power will vary according to my cycling speed (but always higher than 7v).But however much power there is, I want a constant 5v output. I have considered using a linear voltage regulator but they are too inefficient. But I want to know that if the input voltage varies on a LM2596S buck converter module, will the output voltage also vary?
Thank you.
